Question about Lexmark X6170 All-In-One InkJet Printer
My Lexmark 6170 printer isn't working properly. When I try to print something the paper isn't feeding in correctly and feeds in sideways to the right crushing the paper. It feeds so far in, and will continue to try to feed in unless I stop the feed. I've had a look inside and cannot detect a paper jam anywhere, yet it still feeds the paper in incorrectly. Any advice would be gratefully received.
    Genius:
  • 1,087 Answers
This article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on the Lexmark X6150/X6170 might help resolve the problem.
Posted on Apr 11, 2011
Printed copy will not feed out line by line and finally will not feed the printed page. How to get it to work properly?
There could be something blocking the paper path that's not allowing the paper to not go all the way through the feeder. Try to open the printer and access the cartridge area. Remove the cartridges. Check for any foreign objects blocking the paper path. Rebrick your printer by removing the power adapter (black box found on the back of your printer where the power cord is plugged in) and then re-plug after 30 seconds. When your printer turns back on, re-insert your cartridges. Then try print your document again to verify that the problem is fixed.
Nov 10, 2011 | Lexmark X73 All-In-One InkJet Printer
When I print something it does not print straight on the page. Can you help me figure out what the problem is?
Something is making the page feed crooked. Are the "fences" beside the stack of paper up against it to prevent it moving sideways? Also check that the feed rollers are clean and have good friction. Plain water on a cloth will usually clean them well enough to feed properly - just be sure the rollers are dry before you reinsert paper. Use a cloth, not a paper towel, because paper leaves fuzz behind, making the rollers slick. In more severe cases I sand rollers, then clean them, but you need to be careful not to get sanding debris all over the printer.
Feb 15, 2011 | HP Office Equipment & Supplies
Every time i try to print the my paper goes in sideways and doesnt feed into the printer properly what wrong????
There is almost certainly something in the print path that is obstructing the paper. Check to see if there isnt some old paper or something dropped in the paper input.
Sep 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper feeds into printer uneven
check for anything obstructing the path of the paper..usually something very tiny! and clean the rollers with toothbrush & water.
Nov 29, 2008 | Lexmark X2500 All-In-One Printer
Lexmarkx73 Won't feed paper through while printing
Jul 13, 2008 | Lexmark X73 All-In-One InkJet Printer
I cant print,scan & copy
try reinstalling the drivers and/or replacing the cables. Also look for any debris or tiny piece of paper that may be stuck between the rollers..
May 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam
Feb 28, 2008 | IBM Lexmark Z715 InkJet Printer
Paper not feeding through on right hand side
I had the exact same problem.  I disconnected the printer and then when I flipped it upside down, I heard something drop out of it.  Low and behold was my missing letter opener.   I then tested the printer to see if it works, and sure enough it feeds properly.  Try cheecking to see if any objects may have accidentally fallen into it.
Sep 29, 2007 | Lexmark Z735 InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X6170 All-In-One InkJet Printer Logo
249 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
