Question about Mpio FL100 MP3 Player
When I connect my MPIO MG100 MP3 player to my home or work computer, both computers don't recognize it. It did recognize it before, a few months ago, but now it won't. I can open the player on my computer, but I can't download any songs. I can delete songs through the computer, but they still show up on the player. I'm this close in buying a new player.
SOURCE: deep trouble with the memory..
ok you have to format by itself. reset the fl400 by the pinhole then when its off press play and menu at the same time for 10 seconds then press and hold the rec or rew button. after the format, run mpio utility press on setup & conf now you havet it like new
Posted on Feb 03, 2007
SOURCE: windows unable to format my player
  • 20 Answers
SOURCE: MPIO HD 300 Freezes/Computer won't recognize
1. there is a reset button if the player is stuck, there is a hole on the front panel use a paper clip.
2. Hard Drive probably got disconnected from the FPC cable, you might need to open the player to fix this issue
Posted on Dec 21, 2007
SOURCE: My Mpio FG100 is messed up! Help! Please!
lol thats not how .... switch the hold switch on, press and hold func botton press play while holding then turn on the mpio while holding after that a screen saying"preceed to format? press rec hold for N secs til screen pops up saying that its doing a low level format
Posted on Feb 20, 2008
  • 52 Answers
SOURCE: Multiple copies of songs on sansa e250. Unable to delete them.
this will be bery hard for you you need a pc and erase all the files one-one My suggestion format the sansa and clic your pc ONLY ONCE DUD {RATE ME}
Posted on May 16, 2009
When I connect my FY200 to my computer, the computer does not recognize it. What could be the reason for this? Please help. Thanks in advance.
Well check your usb cord. Try using a diffrent one. if that does not work, then you should take your mp3 to a shop.
Jan 02, 2011 | Mpio FY200 Digital Media Player
Frozen MP3 player - MPIO HD300
Have you tried downloading the specific drivers for that MP3?
Here is the site...choose your player then download and install...reboot and see if it solves your problem.
http://www.mpio.com/downloads/index.php
Feb 29, 2008 | Mpio HD-300 MP3 Player
My mpio mg100 keeps freezing, i have to keep resetting it?
Hello
The freezing may be as a result of;
Outdated Firmware
1. Every few months,the manufacturer will publish a firmware update designed to fix bugs in the previous firmware and improve the overall function of the device. To check for updates, connect your player to your computer and open the player software. If you are connected to the Internet, the software will automatically check for updates. If an update is available, a notification window will pop up. Click on the notification to start the new firmware download.
After downloading it installs the new firmware automatically and you are good to go
The freezing might also be as a result of corrupt firmware and you will have to re-format the player,the firmware and all the content will need to be wiped and re-installed.
To do this, you will need to connect your player to your computer,. Launch Windows Media Player while the device is plugged in. Click on the "Sync" button. You should see your player pop up at the bottom of the device list. Left-click once to highlight it, and then right-click to bring up a sub-menu. Select "Format" from the list. All of your content will be deleted and the firmware will be reinstalled.
Aug 31, 2010 | Audio Players & Recorders
How to Replace Battery in MPIO FL300
my mpio FL300 can't conected to my computer,because i've been format it.how to solve this problem?thx.(if ful)
Aug 16, 2009 | Mpio FL300 MP3 Player
Hi, I can no longer browse through the files of my MPIO MG 100.
ok what charge setting is it on? if its on the MTP setting hold the "MENU" down until a message apears that says "reconnect the mg100 to change the mode" then it should work. if not then i guess i wasnt verry helpful and im sorry
Jun 05, 2009 | Mpio Audio Players & Recorders
Dec 10, 2007 | Mpio HD-300 MP3 Player
Unreadable directory by recent windows XP laptop
MPIO Utility can be used with MPIO player that supports USB Mass Storage.
With this, you can..
- Format and Recover MPIO player
- Upgrade firmware of MPIO flash-type player
- Building playlist of MPIO hdd-type player
* Supported OS : Windows 98 SE, ME, 2000, and XP
* MPIO Utility doesn't work with FL200 and FY300.
* If you are using the latest firmware, be sure to use the latest version of MPIO Utility.
* Please uninstall the old version of MPIO Utility before installation.
[Download]You can redownload drivers and first uninstall the old one's.RICHARDM69
Sep 25, 2007 | Mpio FL400 MP3 Player
Computer Won't Recognize Device
Try plugging your USB cable (attached to your player) into the computer before you turn the computer on and boot up . . . I had this same problem with a flash drive that the computer would not recognize if I plugged it into the computer while the computer was already on.
Aug 21, 2007 | Mpio FY500 MP3 Player
Mpio fg200
Turn off the unit and connect it to the computer.
The computer should recognize the player.
Run a program called Mpio Utility (Can be found on the CD or Mpio.com)
Select format & Config
That should do the trick.
Or go to www.mympio.com
Feb 01, 2007 | Mpio FG200 MP3 Player
Mpio not showing up on itunes
We just purchased an MPIO and we are having same issue, media player not recognizing that it is plugged in by USB, however MP3 player is.... Retailer had no clue and said the equipment was not broken.... we have another MP3 (RCA) and it works great !!... need fix
Jul 30, 2006 | Mpio FY200 Digital Media Player
Mpio FL100 MP3 Player Logo
245 people viewed this question
Top Mpio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
