Printer appears to want to print out an infinite number of pages of gibberish from a document sent to it. Obviously, the document info somehow, somewhere screwed up. I don't need to waste an unknown number of pages and ink to get gibberish. How is the printer's memory cleared? I'm running it from a Linux operating system. The document is my confirmation that my Canadian taxes for 2010 were filed. The document was to be a "PDF". Your assistance will be appreciated. Erik Alberta, Canada, eh!
  • 52 Answers
The document is probably not screwed up this happens usually when the computer is using the wrong printer driver. if the pdf looks ok on the screen try reinstalling the printer driver and resend the document. to clear the job from the printer just turn off the printer and clear the print que from the computer.
Posted on Apr 09, 2011
I print out 1 single document of bar code , but the printer wont stop
The print job is not formatting properly for your printer. It keeps corrupting and will cause the printer to spit out multiple pages with either gibberish or unusual fonts of varying size.You may need to recheck the software you've written the bar codes and make sure your using the correct code 39 font to create your barcodes.
Mar 01, 2016 | Office Equipment & Supplies
Prints blank pages and gibberish
You may have to shut down the printer completely, including disconnection of power. When you reapply power, the printer should be indicating it is offline so you will have to put it online again.
Dec 04, 2013 | HP Laserjet Pro Cp1525n Color Printer...
Hi i have Xerox 7760DN with both ps anc pcl enabled - there's a 68 page document getting prited everytime the printer is turned with bunch of gibbersih from startup. DO you know the resolution for
Sounds like a print job was sent to that printer using the wrong print driver. Unplug the printer from the network and see if it only prints the startup page. If so, then you need everyone to cancel the print jobs they sent to this printer. Then hook the network cable back to the printer and see if a print job can be sent to it (one that has worked in the past). I suspect someone has an old printer driver that is using this machines IP address to print to and it is confusing the Image Processor Board...
Apr 04, 2013 | Xerox Phaser 7760DN Laser Printer
When I print a one page document, tray 1 prints on multiple papers at a time. 1 page prints on 5 pages.
If you don't have a manual, you can find one here
My guess is either on the printer or the driver. Skimming the manual, it doesn't seem that you can set the default number of pages printed per sent print job on the printer, but that is something I would look into. This is a nice office printer, perhaps the printer is set to print multiple copies of everything it is sent. You could determine if it is the printer or driver/computer by printing to it from another computer.
If it is the computer, go into the control panel and select the properties for this printer. In there, check if the number of copies is improperly set to 5. This would happen for every print job sent from this system.
Does it print 5 copies of documents sent from different programs (i.e. Web Page, Word, Excel)? Quite possibly, one time you set it to print 5 copies and that application retained that as default. In that application, rather than clicking "print" click "printer setup" and look through the settings to see if it is requesting multiple copies.
I am 95% sure one of these three solutions will solve your problem.
May 05, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Hello. I have a Deskjet 810C, and a friend tried to adjust the settings. Now, when I try to print one full page of a document, it only prints a jumbled portion of one line. After that, it feeds through...
The symptoms indicate that the printer is receiving a data stream that it does not support or the data stream it is expecting (is set for) is not the one it is receiving. This also happens when the printer is somehow disrupted (like momentary power off) during printing. When it resumes, the setup information sent previously for the document has been lost, but the computer doesn't know about it so it sends data to the printer which prints merrily on in gibberish.
If you haven't already done so, try turning the printer off, disconnect the power cord for about 5-10 seconds, replug and turn the printer back on. Check to see whether that resolves the print issues.
If not, run the diagnostics: with the printer already on, press and hold the power switch while pressing the Resume switch four times, then release the power switch. If the problem is internal to the printer, nothing will happen (internal diagnostics should run and the printer will print something).
Assuming the diagnostics ran ok, the fastest way to fix this type of problem is to reinstall the printer drivers and software. Something has probably happened to the driver or the installation which is easiest to counter by reinstalling.
Mar 07, 2011 | HP DeskJet 810c InkJet Printer
The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
Can you send me a "print to file" of the failing document.
At first blush it can be either of two things.
1) The preceding print job did not properly clean out the printer's memory.
2) The new print job, has data or a busted escape command in it that is being treated as printable data.
Send the print file to don.farr@hotmail.com and I'll read through the document header to see what's going on.
Don
Mar 02, 2010 | Dell 1720dn Laser Printer
My mom's hp officejet T45 printer now prints gibberish. It started after my sister installed a new ink cartridge for her. Because her documents were printing nothing but a solid black line then, my...
Gibberish sounds to me that ether one of two things is going on.
1. the printer was never allighned when the new cartridges where put in.
2. Depending on the gibberish its printing it could be a communication error with the driver on the computer.
Do not pitch the printer but get help for it like you are doing now! But I would have taken a chat from us to see what the gibberish is!
Dec 18, 2009 | Cameras
Prints a single line of gibberish on 1 page before printing the document, then eventually spits out a blank page. Running on vista, using vista driver. Dell 1720dn printer on Vista Business SP2
Gibberish? What you are seeing may be printer control codes and data.
Is there any way you can scan the page into an e-mail and then send it to me at don.farr@verizon.net, please.
I'd like to see your printout.
Don
Nov 04, 2009 | Dell 1720dn Laser Printer
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
My Hewlett Packard OfficeJet 500 was faxed a 45 page document, which I accepted (by activating the "Auto Answer" button) and printed. Then, while I was briefly out of the room, a second copy of...
I went back to Control Panel, and, following a hunch, found my way to discovering that the printer had somehow gone into "Pause" mode. I then simply clicked on the word, "Pause" and it converted to "Active."
Aug 15, 2008 | Office Equipment & Supplies
113 people viewed this question
k24674
jasbo
jasbo
