Radel CR208 I have a Radel CR208 portable air conditioner. The problem is everytime I plug it in (220V), it shuts off the main switch in the fuse box. What could be the problem?
5 Suggested Answers
bobotfel
  • 236 Answers
SOURCE: air conditioner
Remote control units have diagnostic program in the
control, after 3 to 5 minutes of operating if the diagnostic
tools detect abnormal operation, then its shutdown the unit
to protect from damage. Thermistor sensor is one of the
parts that detect the operation of the unit. Out of range
or defective thermistor can shut the operation of the unit.
If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
- Out of range thermistor sensor in both return air and freeze up sensor can cause the tripping “off “ the unit. The resistance of both thermistor is 8 to 10k ohms, so can test by using ohm meter
Posted on Jan 12, 2008
SOURCE: RADEL CR 208 PORTABLE AIR CON UNIT
DOES ANYONE ACTUALLY ANSWER ANY PROBLEMS ON THIS FORUM?????????????????
Posted on Sep 21, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
SOURCE: beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Posted on Jul 06, 2010
SOURCE: carrier holiday portable air conditioner manual
Mine has a model number of PCA061D.
If you remove the water capture reservoir, there is a sticker that has the model number.
Posted on Sep 29, 2010
Where is the fuse box on a air conditioner?
in the main power board of the building
motor compressor split system has an on off switch
if a hole in the wall type air con unit
with plug in a wall socket
its a normal power fuse
Jul 23, 2016 | Heating & Cooling
Convair portable air conditioner won't turn on
Hi Corbi, the first thing you have to be sure if the right volatge is on the outlet box, 2nd, if the fuse on the A/C is good and may be, it sound like a yoke, if you have seen ans around your selector switch. If yes you know enough. I hope it was helpful to you!
Feb 03, 2014 | Convair Portable Air Conditioner
My conditioner Sharp CV-P12LX shuts down after 10 min of operation. A noise is heard in the plug reset switch as well
If you have to reset the plug then its pulling to many amps. If you don't know what else is connected to that particular line (in your breaker box) you might consider using another outlet. Increasing amps. of breaker may not be advisable without consulting an electrician.
Jan 24, 2011 | Sharp CV-P09LX Portable Air Conditioner
Power turns on but nothing else turns on, just the display screen. is there an easy fix ie fuse or something?
CHECK BREAKER AT MAIN BOX , SHUT OFF BREAKER ALL THE WAY OFF AND BACK ON. IF YOU DO NOT HAVE BLOWER WHEN YOU TURN FAN SWITCH TO ON THEN YOU STIIL HAVE NO POWER TO UNIT . GO TO OUT SIDE UNIT ON GROUND AND PULL OUT DISCONNECT FUSES AND TEST THEM OUT OF FUSE HOLDER LIKE AUTO FUSES. IF UNIT IS ON ROOF SHOULD HAVE FUSES UP ON ROOF IN 6  X4 GRAY BOX. SHUT OFF BREAKER FIRST BEFORE FUSE TEST. IF FUSES OK AND BREAKER OK THAN YOU MIGHT HAVE BLOWN TRANSFORMER.
Apr 21, 2010 | Danby DAC9003D Air Conditioner
We have a heater whose thermostat switches broke a week ago. Am desperately looking for a wiring diagram for it. It says Radel thermostat on it. I would like to set it to be constantly on, whenever we...
usually the thermostat has only two terminal wire, it acts like a lamp switch, will open and close according to the temp setting. L1 usually pass trough the switch and L2 directly connected to the load or heater.
Jun 07, 2009 | Heating & Cooling
Plugged 120v window AC into a 220v socket
Window air conditioners generall do not have fuses.
Jul 24, 2008 | Heating & Cooling
Jun 24, 2008 | Heating & Cooling
Basic electrical diagrams
LOWES DEPARTMENT STORES-- HOME DEPOT!
Apr 29, 2008 | Goodman PHKJ048-1 Air Conditioner
Heating & Cooling Logo
354 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
