Question about Sony KDF-E50A10 50 in. LCD HDTV
My T.V. will not come on.... Green light blinks for about a minute, then red lamp light begins to blink and continues... never stopping. The fan runs while the green light is blinking but stops when the red light comes on.
  • Sony Master
  • 3,459 Answers
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 01, 2011
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony 50inch tv red light blinking continuously
I will need the model number of your sont because different model numbers have different diagnosis codes.
Aug 02, 2012 | Televison & Video
I plugged in my xd490u [mitsubishi] data projector...and then power turned red, status turned green for few some seconds. later power blinked [red + green] and did not work. can anyone tell me what the...
It sounds like your lamp may need replacing. Before you go that route try all of these:
-Make sure the lamp cover on the bottom is fully attached. -If you unplug the power cord while the fan is rotating, the lamp may not turn on about 1 minute when you plug the power cord next time. After the status indicator stops blinking press the power button to turn it back on. May have to press it multiple times. -If your Power Light continues to blink red/green then you should contact your dealer.
Sorry I couldn't be more helpful.
Feb 28, 2011 | Mitsubishi XD490U Multimedia Projector
TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Apr 08, 2009 | Sony Grand WEGA KF-50WE620 Television
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
May 15, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Sony KDF-E50A10 50 in. LCD HDTV Logo
218 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
