Fan on the outside of house will come on but the blower in the house will not come on so there for we get no air in the house
  • 1 more comment
  • Robert Apr 09, 2011
    Can you check if you are getting a 120 volts at the speed terminal and neutral at the control board
  • brandiramos Apr 09, 2011
    k im not sure what you are talking about but this happened about 1 year ago and the service man who looked at it said it was a simple burned fuse. Problem being I dont know what fuse to replace and if I can even do it myself
    Im asking you if you are getting a 120. Volts to the blower motor
    Sergeant:
    Champion:
  • 247 Answers
Damage indoor fan check the fan if stack up apply lubricant also check bearing or bushing and shaftinh if good if not replace new fan motor
Posted on Apr 09, 2011
Air conditioning condensor on side of house not working
sounds like you need to check your run cap it is silver in the outside unit and it runs the compressor and fan motor. Check on the capacitor what size it is and replace it for example 45+5 uf.
Sep 07, 2014 | Carrier Heating & Cooling
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
What happens if you turn switch off outside
Only your blower on the inside will work only blowing the air around the inside of house.You get cold air from outside uni.If you just want it to circulate air then turn it off at thermostat and change the auto mode to fan.
Jul 28, 2012 | Heating & Cooling
Does my unit have a blower inside the house as well as outside or just inside? please explain remote display symbols
Hello
Yes there is a blower fan located in the unit in the home.What this doeas is moves the air out to the vents in the floors or walls.
Also there is a fan outside.This is used for air conditioning.What this fan does is keeps the condensor cool by disapating heat away.
Sep 26, 2011 | Heating & Cooling
My A/C is operating outside the house, but there is no cool air inside the house. We set the temperature onto 84 F Degree, however, the inside-house temperature has already reached 88 F Degree. Can you...
With such limited information the following is the most likely problem.
1. The fan outside is running but the compressor is not.
2. The inside air handler blower fan is not working.
3. The system is froze up and not allowing any cold air to come out of the vents.
Hope this helps
Sep 19, 2011 | Honeywell Heating & Cooling
Maytag dryer
it sounds like there is no air flow check outside of home where vent exits house there should be strong air flow it either a blocked venting or a bad blower fan in the dryer most likely blocked venting start outside then work your back to the dryer if no air flow outside remove venting from the dryer ifgood air flow here the vent is blocked if not blower fan most likely broken these blower fans drive hub round out on the motor shaft of the motor but it would be very loud this should fix it for you thanks kevin
Sep 30, 2008 | Whirlpool Dryers
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
