Question about Napoleon PT450RBI Propane
I am unable to remove my burner tube from my PT450RBI. There is no screw visible for removing the tubes from the back wall
  • 43 Answers
Call Napoleon at 866-820-8686.
Posted on Apr 21, 2011
Viking gas oven model # VGIC3656BSS, serial #022404-2919 takes FOREVER to preheat up. Sometimes in excess of 40 minutes. Been a problem for a while. Looks like flames at bottom do not increase when oven...
When increasing the temp. on a gas range the oven's burners do not increase flame size as the cooktop burners do. It just keeps the burner lighted for a longer amount of time.
First if you can see the burners do they light within about a min. or less. If no you probably have bad igniters which are not lighting the burners as quickly as they should or they are "opening up" (stops working) when they get too hot. In this case replacement of the igniters should solve the problem.
Second if it lights quickly but still takes a while to heat; you want to look at the burners to ensure that the flames are down both sides of the burner tube and not dancing around too much. If only part of the two sides of the burner tubes are lighted then a pluged orifice or burner tube is the most likely cause. Once cleaned it should work fine.
As with anything mechanical there are numurous possiblities for something not working correctly and above are the two most popular reasons that come to my mind.
May 17, 2011 | Viking VGRC485-6 Gas Kitchen Range
Replace burner tube from GE stove
two screws on the back wall usually one or two on the front lip also remove the ignitor from the burner tube before you take off the burner tube be very careful not to break the ends on the ignitor or you will have to replace the ignitor as well hope this helps
p.s. look inside your oven with a light this is a very easy fix and makesure u unplug the power before working on your appliance
Aug 11, 2010 | GE Ovens
Where is the oven igniter located at in a Frigidaire single gas oven located if I need to replace it?
remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle, so it is easier to remove the burner tube. Remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. There is also a video at www.appliancehelponline.com/servicemanual.html that walks you thru testing this part. You can also enter your model # for diagrams and illustrations.
Apr 09, 2010 | Frigidaire FGB24L2A Gas Single Oven
Steps in replacing 5 burners on Ducane burner mod 30400042
First calll Weber to get your replacement burners for free. There is a five year warranty on this model which is a little over 4 years old. I know this because I just received them from Weber for free.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 20, 2009 | Ducane 30400042 (LP)
I have a ducane stainless steel ducane 30400042. Weber has sent me new burner bars since the old ones rusted but you do I install them?
Jun 20, 2009 | Ducane 30400040 Stainless Steel Grill
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Jun 07, 2009 | Ducane 30400042 (LP)
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Apr 16, 2009 | Ducane 30400042 (LP)
Meridian 5 burner trouble
Yes you can fix it. Carefully remove the screws that hold the panel where the burner knobs are, There are 3 screws on each panel under the side shelf. There is another screw up underneath the face plate as well. Once the screws are out pull the face plate up and out so that all the tubes are disengaged. It should rest about 2 inches tilted back. Now remove the grates and burner covers and inspect the burner tubes. You will most likely find that spider webs or hornets have blocked off the gas flow to the burner. carefully clean every burner tube out and put everything back. You also may want to use a bit of sandpaper on the ignitor tip. Put everything back together and you should be good to go. It seems all Ducanes attract spiders on the burners...
Apr 06, 2009 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
How to change the burners
Mar 30, 2009 | Ducane 30400040 Stainless Steel Grill
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Napoleon PT450RBI Propane Logo
47 people viewed this question
Top Napoleon Grilling Experts
Paul Carew
Lawrence Oravetz
Pierre Legault
Are you a Napoleon Grilling Expert? Answer questions, earn points and help others
