Question about HP Photosmart D7160 InkJet Printer
Error coded resetting printer
You mentioned about resetting printer software....
How do you do this ?
thanks
dart
  • gold4u Dec 01, 2008
    I Have replaced the all the ink cart on my hp D7160 ,but know the Light Cyan Ink Cartridge does not work i tried to reset the printer (complete procedure) but still the cyan light doesnot work. what should i do.
    help me anyone
    Thanks
Please send me resetting code
Posted on Oct 26, 2008
I am having the same problem
I Have replaced the all the ink cart on my hp D7160 ,but know the Light Cyan Ink Cartridge does not work i tried to reset the printer (complete procedure) but still the cyan light doesnot work. what should i do?
Posted on Dec 13, 2009
My printer samsung CLX6220FX, have "image error" how reset this error??
Dear
pl.mention prior works done to the printer. image error occure when firmware upoladed which is not for the printer.
do off the printer and on it.
thanks.
Mar 02, 2015 | Samsung CLX6220FX AllInOne Laser Printer
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
Jul 24, 2014 | Samsung SGH-T499
Need code for samsung dart
Hi what code are you looking for .If your Samsung Dart mobile is locked to network then visit Superunlockcodes.com here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.If you forget security code then try default code to reset your mobile.
Aug 21, 2012 | Samsung T-Mobile Dart SGH-T499 GSM Android...
Error 6000
This is the error code printer Canon IP1200, IP1300, etc. light blink Indicator:
3x orange 1x Green = mechanical error
if you dont have any knowlegde about printers, better bring your printer to Canon service center.
4x orange 1x green = printer absorber full
reset your printer using software ressetter or try using manual reset. different printers have different manual reset.
5x orange 1x green = black cartridge/color cartridge error
can be chip error or connector is dirty.
7x orange 1x green = black cartridge/color cartridge error
8x orange 1x green = printer absorber full
12x - 17x orange 1x green = cartridge detection error
How to Reset waste ink counter Manually 1. Unplug power and USB cable. 2. Open door and hold power button. 3. Connect power. 4. Close door, then release power button.
How to Reset waste ink counter using Resetter
1. Download software for Canon iP1200 printer. DOWNLOAD 2. Unzip downloaded file to any location using, 7ZIp, WinRAR, Winzip, etc 3. Run GeneralTool.exe 4. select connected USB port number from USB port 5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION 6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. the selected waste ink counter will be reset.
Thank you for posting. Hope this helps.
Jul 06, 2011 | Canon PIXMA iP1200 Photo Printer
Can u help me how to fix canon printing model is mp258 , error number is 6000, what is problem? thanks
Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
Mar 29, 2011 | Office Equipment & Supplies
I removed the paper jam from the drum of my Brother 7050 printer but it did not reset. What can I do now?
Printer rules for reset and troubleshooting hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving
Jan 31, 2011 | Brother HL 7050 Laser Printer
How do i fix an engine interface error on my brother 1230 printer
Printer rules for reset and troubleshooting hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Jan 30, 2011 | Brother HL 1430 Laser Printer
I keep getting mssg : check printer error 5B00. i found the answer to this, its about ink or something. after i clean the pad, and i connect the printer again, but i still get the same problems..... some...
Hi guys, Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber. Unfortunately you don't write the printer model so I cannot write reset procedure here.
Jun 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX 308
How to reset canon MX 308 ??
Error Code 5800
Any Software to reseter this printer?
Feb 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon Pixma MP800
you need to clean and calibrate them..you'll need to do that from the print manager, under maintenance
Apr 14, 2008 | Canon Pixma MP800 All-In-One InkJet...
HP Photosmart D7160 InkJet Printer Logo
1,253 people viewed this question
Seeker5211
Seeker5211
