Question about HP Deskjet D1455 InkJet Printer
HP DESKJET D1660 will not feed paper into machine
    New Friend:
You have to remove the 3rd clip on the back behind the back panel. its like a beige or white color there is 5 of them (its the one little different than the other) and try to put a bit of clean water on the brush above the main feeder, remove the clip by just pulling the two little clips on it and it should work if you tried everything else and its not working, but make sure your feeder is clean and spin properly.
Posted on Apr 28, 2013
  • Dany Arseneault Apr 28, 2013
    and this is for D1660 will not feed paper
  • 21 Answers
SOURCE: HP F4280 deskjet all in one printer paper feeding problem
See page 94 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Posted on Jul 06, 2009
eagle338
  • 4889 Answers
SOURCE: driver needed for hp deskjet 710c
here you go...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=59307&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Oct 27, 2007
  • 11 Answers
SOURCE: The power light and the paper feed light are both
you going to have to go inside the printer and check for loose cables on the main board. if all cables are ok , i suggest changing the main boar.
Posted on Apr 07, 2009
SOURCE: HP 920c Deskjet feeds blank paper constantly.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Posted on Dec 07, 2009
  • 7 Answers
SOURCE: HP deskjet 3845 will not feed paper to print
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Posted on Jul 14, 2010
Printer can't pull paper
Usually the reason is the rubber rollers that feed the paper have been burnished smooth or are contaminated.
First clean the rubber roller surface with rubbing alcohol - re-try printing. If this fails, scuff the surface of the roller with 120grit sand-paper.
Good luck.
Mar 03, 2015 | HP Deskjet D1660
Hp deskjet D1660 Pulls papers non-stop and output is blank. New tricolor cartridge just put in. Pulls papers uncontrollably. please help
first check it right side feeder assay latch is ok or not if it is broken then only continues paper pulls out ...
Apr 22, 2014 | HP Deskjet D1660
Hp deskjet D1663 Pulls papers non-stop and output is blank
Perform a head cleaning process in you printer, If it is not helping the print head is faulty, take it to service shop
Apr 22, 2014 | HP deskjet d1660 inkjet printer - color -...
My deskjet came with disk d1600 series it should have had d1660
Your HP Deskjet D1660 printer belongs to the HP Deskjet D1600 printer series. That means, the disk you have is for all the printers of the D1600 family, including yours (D1660), so you will not have any problem with the software it includes.
Apr 06, 2014 | HP D1660 InkJet Printer
Free installer of HP Deskjet D1660
HP Deskjet D1660 Drivers
Please visit the above link from HP Official Support. Select the Operating System you have on your PC and download/ install the required drivers for Free!
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Computers & Internet
Loud clicking/clacking when paper feeds
Your rollers may be worn and when they are trying to pick up the paper they are not able to . Buy taking your printer to an authorized technician for a maintenance cleaning this should resolve your issue.
Jun 08, 2010 | HP D1660 InkJet Printer
My printer won't feed paper
To resolve the issue please clean the paper feed rollers,you will get the instructions from the link below...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=..........
Apr 11, 2010 | HP DeskJet 882c InkJet Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
PAPER MANUAL FEED
put a piece of paper in the manual feed tray and press "print"
Apr 09, 2009 | HP DeskJet 6540 InkJet Printer
HP Deskjet D1455 InkJet Printer Logo
522 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
