The TV recognizes the HDMI connection, but says there is no signal. I called Samsung and they said that their products do not support Apple TV. Is there a way around this?
    Guru:
  • 276 Answers
All I can tell you is what worked for me.
IMPORTANT: Be careful! This Menu has very important parameters which you should not change at all.
  1. Turn off the TV
  2. If you have a 52" Series 6 model (my case), press 'Mute -- 1 -- 8 -- 2 -- Power.' If you have a Series 5 model, try 'INFO MENU MUTE POWER.'
  3. The TV will start and you will be in the service menu (give it a few extra seconds to get there).
  4. Using the arrows/enter buttons, go into 'Option Table (Service)'
  5. Turn off the following parameters: hotplug and hotplugctr.
  6. Turn off the TV.
That's it; this worked for me and my set no longer loses the HDMI signal from the Apple TV.
Posted on Apr 09, 2011
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
How do I install apple products
Assuming your tv has an HDMI port, you simply need an HDMI cable from the Apple TV to the LG. On the LG, choose the HDMI input you connected to, and follow the prompts to set up the Apple.
Sep 17, 2014 | Apple Televison & Video
Bravura not recognizing an Apple TV signal
You need to connect using an hdmi cable from the appletv to the tv, and notice which hdmi socket on the tv you use (eg 1 or 2 or 3...) Then make sure the light is on green on your apple tv by using the supplied remote control to power it up. And then you need to make sure you have chosen the correct hdmi source on your tv remote control (eg hdmi1 or 2 or 3...).
Sep 16, 2014 | Televison & Video
The hdmi no is working
HDMI is a little trickier than most think. The signal has to be matched from the source to the TV. This is a little dumb but try this first. power down everything connect the cables (HDMI) and then power everything up at the same time. If it does not recognize the signal at this point I would look into a device to do the signal conversion. The product I use for this is from Key Digital.
Apr 08, 2014 | Sony KDF-E42A10 42 in. LCD Television
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
Dec 29, 2009 | Apple Computers & Internet
32 in Astar LCD won't recognize input signal
Hello, According what you saying not recognize any iput. Then your main board is defective.
The HDMI and the YPbPr are the same connection according the main board build. Any other question please call 323-767-6030.
Jan 08, 2009 | Astar LTV-3201 32 in. LCD Television
Samsung DLP HL-R6167W
Most likely the digital board will have to be replaced. Not a cheap part, so you might concider using the component inputs for now if too expensive.
Jan 23, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
