Question about ASUS Motherboard P5qc
I have pq5c that is aways crashing will not load operating system
    Problem Solver:
  • 17 Answers
In my experience, this is often caused by bad memory. To test this, from a working computer, download Memtest 86+ and burn the ISO to a CD with a program like ImgBurn. Then, boot from the Memtest CD. You can try testing one chip at a time to narrow down which one is giving you errors - just remember, if you find one, the other might still be bad, so test it too!
If there is an error, Memtest will display the failing memory address in red. If the tests all complete with no errors, it will repeat the tests from the beginning, however, it will say "Pass complete, press ESC to reboot" or similar on the bottom of the blue testing screen.
Also, this could be caused by a bad power supply. Try using a known good power supply with the board.
As well, make sure that the screws that hold the board to the case (chassis) don't have the non-metallic washers in between them and the board if the hole in the board is metallic. In other words, if the hole has metal that can contact the screw, it NEEDS to have the screw contacting it for a ground. If there is NO METAL on the hole, you can use the non-metallic washers.in between the screw and the board.
You may also have a problem with the CPU having an incorrect amount of thermal compound between it and the heatsink - it should be a very very thin coating over the entire surface that you can almost make out what the words on the CPU say.
If it still won't work, the problem could also be caused by malfunctioning components - try removing them and plugging them in one at a time (CD, hard disks, USB devices etc - use known good replacements).
Lastly, the board itself may be defective. See if you can contact the manufacturer for a replacement if it's under warranty. If not, maybe you can find a new one for cheap on ebay (make sure the seller has a high number of ratings and a high percentage (95% plus at least) of them are positive.
Posted on Apr 09, 2011
  • 961 Answers
This is Asus's download site and it looks like it supports Windows 7. Your info is there just choose o/s. No on board video so you must have a graphics card or eqiuvalent. Sockey 775 Intel p45 and ICH10R chipsets and Realtek ALC1200 audio. Give me the make and model of your video/graphics card and I can help you with that. It very weel could be the graphics causing your problem.
http://www.asus.com/Product.aspx?P_ID=ShiLE9XNeuFKwFDC
Error 08-0E89-0000 satellite p205-s6237
Your operating system is crash thats why it is not able to load the operating system. If it is showing RAW FILE SYSTEM then you have to reinstall operating system.
Aug 02, 2012 | Toshiba Satellite P205-S6237 Notebook
My e machine e525 keeps crashing. Windows 7 is loaded. Please help
If the OS keeps on crashing, it may be due to the issue with the Hard disk. If the system is still under warranty then you can ask them to replace the Hard disk stating that it keeps on crashing.
Or if the machine is old, then you can buy a new hard disk and replace it with the old one...
It should work...!
Plz comment back for any queries...
Cheers... :)
Jul 20, 2011 | Acer Computers & Internet
My daughters tecra m1 refuses to format and install.it gives disk is not accesible.i can fenagle it to get past that, but it just stalls out.ive ran chkdsk,etc.all checks out.puzzled.loaded operating...
Either the HDD controller is bad or the HDDs you used have bad sectors.HDD regenerator software alot of times will correct the bad sectors and then the OS will install correctly and function smoothly.
May 06, 2010 | Toshiba Tecra M1 PC Laptops
Does loading windows operating system solve all computer problems
yes, it certainly does. Loading windows operating system will wipe away all former files on your computer and new once (files) would be installed, thereby, making your computer be like a new one.
This will also make your system run faster and perform better, because the Hard-drive would be free from load. Also all hidden virus will be wiped away.
Therefore, loading windows operating system, mainly solves software problems.
Good luck.
Apr 12, 2010 | Dell Computers & Internet
Hello my boot disk is crash now. so , had to
Maybe rescue the data by booting from a LIVECD like PUPPYLINUX and transfer all files to a working hard disc. then reinstall system.
Feb 13, 2010 | Computers & Internet
Operating system loading problem on boot up, frequent crashes
Problems like these are terrible to diagnose, and there are thousands of possible problems here - from bad sectors or hardware, to driver and software corruption. BUT, unless your best friend is a geek with lots of time to spare, let me cut to the chase for you.
You can press F8 to choose a logged boot, then review the boot log (C:\bootlog.txt usually), but if you aren't that technical, you may not understand the listings there, or the significance of what is or isn't there.
The best solution is to start fresh. If you can boot to a normal OS, even if it takes you 10 times of trying, do so, then back up all of your precious info to another drive.
Once that's done and you're sure you got it all, use your recovery disk to blow away the hard drive and start from scratch - repartition, reformat, the whole works. It will take some time, and you may have to hunt down some driver updates, but in the end, you'll have a happy, healthy (and fast) PC.
Jun 09, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Vista Home Premium crashed. Reloaded, www, graphics driver no-go
I would try to use the System Restore feature, if you have not already. Choose a date prior to when it crashed on you and it should work.
Mar 17, 2009 | Microsoft Windows Vista Home Premium with...
Operating system not found
Operating system not found? I have got Windows Boot Genius to fix problem safely!
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
No operating system loaded-toshiba equium m50 244
Hard drive crash, drive defects in the area where the O/S is, or, corrupted O/S files.
Download the hard drive manufacturer's diagnostic software and run it. It will examine your drive and give you an evaluation.
If it tells you the drive is fine, the either a complete reload, or a repair will get you back up and running. Whether you will be able to recover any of your data, will depend on the drive condition.
Nov 28, 2007 | Computers & Internet
ASUS Motherboard P5qc  Logo
184 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
