After cycle the door will not open - Washing Machines
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor. The bit about checking the motor is near the end ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly.
Thanks and good luck!
John C
Posted on Apr 09, 2011
Sigla f26 sulla lavatrice
F26 DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds. Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Oct 22, 2014 | Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool aquasteam 6 sense model number 859297015700 error code f26
DOOR SWITCH ERROR
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
-Door switch open while door is locked.
Thanks for using FixYa
Mar 04, 2011 | Whirlpool Washing Machines
What does f26 mean
DOOR SWITCH ERROR
Thanks for using FixYa&^%$
Feb 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Keeps flashing f26 fault
DOOR SWITCH ERROR
5 seconds.
Dec 24, 2010 | Whirlpool Washing Machines
Whirlpool wfw8500sr01 door locks and does not start F24 f26 f28 error codes
DOOR SWITCH ERROR
Dec 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is f26
DOOR SWITCH ERROR
Thanks for using FixYa$%^
Dec 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport dryer getting an f26 error
DOOR SWITCH ERROR
Thanks for using FixYa*&^
Nov 27, 2010 | Whirlpool GEW9250 Electric Dryer
Error f26
DOOR SWITCH ERROR
Thanks for using FixYa $%^&
Oct 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
