Question about Dryers
We bought a brand new gas dryer. model mgdc200xw0 i ran it one time for a cycle and it wasnt heating. we realized it was a natural gas dryer so we got it converted to lp and it still wont heat.
  • 413 Answers
Check your vent. It may be stopped up.
Posted on Apr 10, 2011
  • msherod77 Apr 10, 2011
    all new venting wondering if the dryer has a automatic shut off because we ran it with the wrong gas the first time
  • mark92230 Apr 10, 2011
    If you started the dryer for the first time using LP, and the orifice that was already installed in the dryer was for nat. gas, you might have tripped a sensor down by the burner. Some dryers have manual reset heat sensors . These are usually about the size of a quarter with two wires running to them. The reset will be a small button on top of the sensor. These sensors are triggered due to flame roll out which could very well have occurred when you first turned it on using LP
DRYER HEAT TURNS OFF AFTER ABOUT 30 MINUTES
  • Get on with replacing the gas valve coils shown to you in the previous link, it will take care of your problem.
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Jun 07, 2008 | Whirlpool LGB6300 Gas Dryer
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
Bought the dryer new and never any problems. This morning started a load of clothes, ran thru normal cycle, still damp when beeper went off. Ran again and realized there was only cold air blowing. ...
Hello my name is Heath it will be my pleasure to assist you. I would check the vent hose behing the dryer and make sure it is not clogged and also check the outside termination for being clogged up with lint and hair.
Oct 08, 2010 | Dryers
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
My dryer will not heat up
You don't wan't to mess with this. Its probably something small like a defective thermopile, but repairs around the gas valve should be done by a professional. The thermocouple and photocells are safeties.
Apr 26, 2009 | Dryers
Dryer not heating
Jan 08, 2009 | Frigidaire Dryers
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
