Question about Arris WR850G Router (DHWR850G)
Motorola WR850G I have a Motorola WR850G wireless router connected to a Motorola dsl modem and a HpPavilion pc. Everytime there is a power outage my pc will not connect to the router\internet but the laptop will.
    Sergeant:
  • 306 Answers
Right off the top I can imagine that the laptop is smirking because it has a battery to get it through the power outage. What may be happening is that the desktop loses it's ip address or the router defaults back to DHCP rather than PPPoE which is where it belongs for DSL. 3 ways to fix this:
1) Reset the power on the DSL modem and wait a minute or two.
2) Go to Start>Run>type 'cmd', Enter, type 'ipconfig /release' then 'ipconfig /renew' then 'ipconfig /all' to see all of the ip addresses for each adaptor and gateway.
3) Go to Start>Run type 'http://192.168.10.1' and a logon window appears. User name is 'motorola', Password is 'admin'. A webpage appears showing you are now talking to your router. In the LAN tab choose PPPoE for automatic DSL control settings. You can also temporarily select DHCP to use the 'Release' and 'Renew' buttons here which is the same as the ipconfig commands you did at the Command Prompt in step 2 but reselect PPPoE before you leave the router control panel. You can also select STATIC if you already know your ip addresses but for DSL you normally use PPPoE. If you haven't done this before then peruse all of the other controls that you can access here. (If you are a gamer this is where you set up your DMZ and so on.
Have a nice day, Steve Medley
Posted on Oct 16, 2008
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Secure motorola router WR850G
If you want set wireless router with connect your internet, in that case you should secure your wireless router.The router transmits and receives data from the modem and computers connected to the network....read more: how to secure your router
Aug 28, 2012 | Arris WR850G Router (DHWR850G)
Our internet went down for several hours (it was an area-wide problem with our server). Once the internet came back up, my motorola 850G router will not work. I have reset the router, but the modem light...
(It worked for me for WR850G, when I had a similar issue. However, don't know how your connection is setup.)
1. Switch-off the ISP modem that connects to the router
2. Switch off the wireless router
3. Now switch on the ISP modem
4. Switch on the wireless router
Regards,
Warija
Dec 22, 2008 | Arris Wireless G Broadband Router (wr850g)
No connection with router
Check all the cables and connections first. Recheck if you did a good connections
Check if the router is working properly.
Check if the router is on range
Reset the router
Nov 19, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
Aug 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Slow speeds is caused by interfearace from cordless phones. 2.4ghz. also could need a power cycle. unplug the power from the back of your dsl modem. unplug the power from your router. shut down your computer. Plug in the modem frist, wait until all lights are green. plug in the router. then when lights are normal on that. turn on your computer. try your connection again. is it slow when you try to acess the router ip address?
Dec 06, 2007 | Arris WR850G Router (DHWR850G)
Arris WR850G Router (DHWR850G) Logo
242 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
