Question about Disney Mix Max Digital Media Player
I can not charge the battery
When I connect the unit to my computer to charge the battery, nothing happen. The USB symbol does not appear. why?
help me thanks
  • 5 more comments
  • kaizar Oct 13, 2008
    MY PC DEMANDS FOR A DRIVER SOFTWARE WHEN IS PLUG IN
  • detyge Oct 17, 2008
    Trying the firmware reset...
  • Anonymous Nov 22, 2008
    I can't charge my player---nothing happens when I plug it into the computer.
  • hsteven Nov 28, 2008
    Mixit is dead, and cannot get the computer to recognize the usb hookup.
  • superjenni4 Dec 03, 2008
    it can't charge and it tells that Windows cannot recognized the device. Please i need HELP!!!!!!!!!!!
  • mslrob01 Dec 08, 2008
    I can not charge my daughter media player and she only used it less than five times.
  • jessicahutch Dec 26, 2008
    I have the same problem what do I do?
    Scholar:
  • 93 Answers
Try using a port on the back of your computer. The Universal Serial Bus (USB) can only provide 500 Milliamps of power and in most cases the ports on the front are a shared bus so they can only provide 250 Milliamps of power. This may not be enough to charge the player. In most cases each USB connection on the back of your computer is a seperate bus and can provide the full 500 Milliamps necessary to charge the player. If that doesn't correct the issue you can try flashing the firmware and see if that makes a difference. Below is a link for the instructions for flashing the firmware. If that doesn't correct the issue you may need to contact their customer service and find out what you need to qualify for a warranty replacement.
Firmware Flash Link
http://digiblue.com/customer-service/faqs/disney/mixmax/17.html
Posted on Sep 24, 2008
Tablet not charging while plugged in
Turned off the tablet, unplugged the charger and kept the tablet off for about 30 minute to one hour, plugged in back the charger, then turn on the tablet. After that I you might see the tablet started charging. Good Luck.
Jul 10, 2015 | ASUS MeMO Pad HD 7
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB...
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB cord to charge the battery on the screen appears the following: IDLE and some kind of symbol. Can you please help?
Dec 16, 2010 | Truly MP310 MP3 Player
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
My blackberry curve won´t turn on unless its connected to power. When it is connected the battery symbols appear in red and with the charging symbol, but when i disconnect it, it says that the battery...
well sorry about that but the only thing you can really do is call your carrier and get them to fix your phone with insurance and if you dont have that then your just gonna have to either bumb 1 from a friend or family memeber or a friend or just buy a new 1... i had this problem and i tryed 2 different batteries and it still did the same thing the only thing that work for me is because i got lucky is i bought a new charger and then i let it sit for 24 hours with out playing with it and the next day it worked fine so it might just be a shortage in your charger if you have a usb cord try to plug it in your computer and see what happens
Aug 22, 2009 | Cell Phones
I just received my Garmin for XMAS and it was working fine but now it just seemed to not charge. Then the little pic on the front shows the GPS connected to a computer desktop. HELP! Amber Fader
Does it turn on at all? Try to charge it on car adaper then, when it will turn on, try this.
The picture is displayed while it is charging through USB cable and you can't normally use GPS.
Turn the GPS on without the USB plugged in, then press the Battery symbol for about 10 seconds, until the test screen appears. Then plug in the USB.
Screen will tell you percentage of charge, and if it is charging.
***Make sure you press EXIT before unplugging the USB cable. Press EXIT, turn GPS off, then remove the cable is safest way
On the bottom you should see "USB type" if nothing is there, it may be the USB port on your computer. Try it again with a different port
Jun 12, 2009 | Garmin nuvi 255W GPS Receiver
Flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
Disney Mix Max Digital Media Player Logo
128 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
