Question about RCA Microwave Ovens
Our RCA compact microwave keeps giving us a code 140. What is it and how do we fix it
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Microwave sounds as though a motor is constantly running. Actually comes on when buttin pressed, runs about 20 seconds, smell odd, trips breaker.
From your description it is more than likely the magnetron has failed, the part replacement is the most expensive and can run as much as a new microwave oven in some cases.
Aug 29, 2012 | Amana RFS12MPS Microwave Oven
I have a Singer Juice Giant II but no instruction manual. Where would I find the instructions?
HELLO.
Way out to the problem.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Microwave Ovens
Need owners manual for Koc-925T-WHI
HELLO.
solution below.
Thanks.
Sep 19, 2011 | Daewoo KOC-925T Microwave Oven
I need to find a User Manual for my DeLonghi Microwave Oven DMX30 - I hope someone can help me.
HELLO.
Thanks.
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
Microwave automaticaly turns on when the door is closed, won't stop.
Check and change as required the door switches.
That should fix it.
Dec 09, 2010 | Oster 0.7 Cu. Ft. Compact Microwave
Model 140 (new) stopped heating
If that is a new appliance, I would call GE and ask them to give you a new one or get someone to fix it.
This microwave should have one year warranty.
Hope this helps.
Feb 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top RCA Microwave Ovens Experts
William Miller
William Miller
Mike Carew
Gerry Harvey
Gerry Harvey
Are you a RCA Microwave Oven Expert? Answer questions, earn points and help others
