Question about Delta 3 Function Showerhead & Grail On-Wall Tub Mixer *Trim Kit...
How do you remove the governor on delta shower head model 75527SN
  • 37 Answers
SOURCE: flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Posted on Nov 12, 2008
manhandy
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
  • 13 Answers
SOURCE: I have a Delta shower faucet model number 1324 and
Hi Shannon:
The problem is most likely the seats and springs. You should purchase Delta Part # RP4993. I found some for mine at Lowe's for around $4.00. O-rings are available there too for about $2.00, and you probably should go ahead and replace them as well, especially if they feel dry and brittle.
You have to remove the handle, then unscrew the brass ring (or bonnet) with a pipe wrench, then just pull the cartridge straight out. Separate the lower cartridge from the upper by twisting a quarter turn to the left. Once separated, remove the black rubber seats and springs and install the new.
Posted on Oct 12, 2009
  • 81 Answers
SOURCE: How do you remove the temperature knob and cover
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
Posted on May 29, 2010
How do i disassemble and clean delta a112.18.1 shower head
Over a period of time the minerals in our water can build up when run thru small openings, CLR (calcium, Lime, Rust) remover and cleaner will remove these deposits, mix according to label in a bucket, remove shower head and place in bucket overnight. remove rinse and reassemble with Teflon tape thread sealer.
Feb 28, 2015 | Delta Home
How do you adjust pressure on delta 1348 one handle shower? Thanks for your help, Al
There is not water pressure adjustment on this faucet if the pressure from the shower head has gone done from what it was after the new install remove the shower head and clean it and make sure any inline filter screens are without debris.
Feb 09, 2011 | Delta & Single Handle Shower Faucet
Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
May 30, 2010 | Delta Home
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
How to turn on shower head of Delta monitor
I'm at my cousin's place and he has a delta monitor. Similar to what you guys are talking about.
To turn on the shower, I had to pull down on the faucet head, not the shower head.
To turn off the shower, I had to push the faucet head back up.
Hope this helps anybody out.
Mar 24, 2009 | Delta T13420 Chrome Classic Single Handle...
Low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Dec 05, 2008 | Delta Faucet Company RP26755 Sleeve...
Delta 3 Function Showerhead & Grail On-Wall Tub Mixer *Trim Kit... Logo
327 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
