Question about Refrigerators
My Avanti Wine chiller WC5101DZD is now makng a loud motor noise and the lower portion is freezing my wine. The LCD dipslay is also no working. Thanks
  • smarti02 Aug 18, 2008
    same problem
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: where do I locate the
look in the bottom in the back if you dont have a manuel go here http://www.avantiproducts.com/index.php?page=manuals
Posted on Mar 19, 2008
SOURCE: danby wine chiller
I found the solution to my case. The continuous compressor running problem started a few days after we moved the unit from a hardwood floor to a room where it is on a carpet. For some reason, this caused some sort of freeze up. I solved the issue by raising the unit about 1/2" using a couple of boards I had and placing them under the legs. Now I need to figure out a bit more visually pleasing solution, but raising it up cured my freezing problem.
Posted on Aug 24, 2008
  • 85 Answers
SOURCE: Avanti wine cooler temperature problem
Fixya repair directory link
http://www.fixya.com/repair
this is the direct link for repair service enginers just select the proper unit of yours and your area  location.
Posted on Mar 02, 2009
SOURCE: thermal coupling in wine chiller
No, I would not recommend putting water into the chill chamber since if there is a "gap" hole in this compartment, the water could get inside the unit's electronics etc.. which could at the very least short the unit and at worst electrocute you as you take the bottle out/touch the unit. That's the problem with this or any other Peltier/thermoelelectric type of chiller. They are only good for maintaining an ALREADY cold bottle's temperature, not for chilling it rapidly. There is no good or inexpensive way to get better chilling from these types of units. It's the law of themodynamics and heat transfer. Water is the best/safest/most inexpensive medium to use, not chilled air or even super cold air. Cold air or even super cold air just does not match the chilling potential of a liquid like water. The reason why 50F air is no problem, for you to be out in for hours, but 50F water you'll get hypothermia in 20-30 mins.
The best unit for chilling a warm wine bottle is the cooper cooler. Go to www.coopercooler.com. It uses ice and water and sprays the ice cold water over the bottle while spinning it to chill it quickly. This unit is great since it can also chill single serve drinks like beer/soda etc so is more versatile than the other chillers. Cheapest is about $59 which is much less than the waring at ~$100
Posted on Apr 14, 2009
I have an older model Avanti Wine Chiller that began making a very loud almost-grinding noise last night. It continues to cool but I have turned it off due to the deafening sound. Any ideas?
first off determine where the noise is coming from what area? I suspect u may have a fan or condenser fan problem restricted , impeded or going out?
Feb 25, 2015 | Avanti Refrigerators
Has anyone replaced a compressor relay on this chiller? Looks like it is not designed for replacement, but if it can be done with a generic relay I would like to know. Thanks.
The cost of one of those compressors is over $100. When you factor in tax and labor you're better off junking it. Its also possible you have a compressorless cooler called Peltier.
Jul 30, 2014 | Avanti WC1500DSS 30 Bottle Wine Chiller...
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
My avanti wine chiller mod ewc 16 b serial n.0800854 stop cooling what can i do ?
I've added a link for an Avanti ewcb,
http://www.retrevo.com/support/Avanti-EWC16B-Refrigerators-manual/id/867bh235/t/2/. There you can find a complete manual on the product which will help you to locate where the problem is coming from. hope I've helped!
Oct 24, 2012 | Avanti EWC16B Thermoelectric Wine Cooler...
Where can I find a replacement thermostate for Avanti wine chiller AP3866842 ?
Hi there, As I do not know what country you are in, I suggest you google it. I just found this one for $14. Obviously you need to contact them direct for the exact match.
Avanti Products Wine Cooler Refrigerator Parts ' Reliable Partswww.reliableparts.com > Home > Kitchen Appliance PartsCached
Jun 14, 2012 | Refrigerators
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
Hi, I have a WCR524SDZD wine chiller and the fan has started to make noises, and also the temperatures seem to not drop to the temperatures we expect. Where can I get a new fan? or parts for this...
your unit uses a generic fan motor that a lot of refrigerators ect.. use. If you take the fan to a local shop that sells refigerators they will match up one for you. Avanti's phone number is 1 800 220 5570. good luck
Aug 11, 2010 | Avanti WCR524SDZD Wine Cooler
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
Oil appears to be leaking from my Avanti Wine Chiller
Is it cooling ok?Where did you find the oil? If is not cooling and you see an oil spot inside or outside where the compresor is that means there's a refrigerant leak.
May 01, 2009 | Avanti WC3200BG Wine Cooler
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
