Question about Kitchen Ranges
Where is the propane/gas sensor shut off. 1992 Fleetwood Southwind 34"
  • 1244 Answers
SOURCE: need repair manual for 89 fleetwood southwind
you can order that from online from haynes or chiltons depending on how much detail info you want
Posted on Jan 21, 2010
SOURCE: i wish to purchase a
You can have an Fleetwood RV Owner's Manual e-mailed to you (PDF) by sending a check or money order for $10.00 to the address listed below; if you would prefer a paper copy sent via US Mail, please send $20.00. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood RV Service & Training Center
PO BOX 1007
Decatur, IN 46733
I would also request you visit the below mentioned link:
http://fleetwoodrv.com/contact/faq_mh.aspx
Thanks and regards,
Anil.B.R
Posted on Sep 08, 2010
racelinec189
  • 365 Answers
SOURCE: how to replace filter (diagram maybe?) in 400 turbo automatic transmission thats sitting in a 1985 fleetwood southwind motorhome?
  1. Check the fluid level. The first thing to check if you suspect that the transmission is acting up is the automatic transmission fluid (ATF) level in the transmission itself. The dipstick on the TH400 can be found inside the engine bay, on the passenger side toward the firewall (opposite the radiator). Pull the handle attached to the dipstick, which will remove it from the dipstick tube. Clean any fluid off and put it back into place, making sure that it seats all the way. Then remove it again and look at the tip of the stick. There are level indicators there, which will tell you if the transmission is low on ATF.
  2. 2
    Check the linkages. The linkages that are connected to the shift lever can get out of alignment at times, causing sloppy or difficult shifter response. Look for abnormalities such as bent or broken parts, loose attachment points, or blockages that would prevent smooth shifting.
  3. 3
    Change the filter. Unbolt all 13 transmission pan bolts (on the bottom of the TH400) and remove the pan. The filter is found in this area of the transmission. Filter kits, which include the filter and a new pan gasket, can be found at any auto parts store. Replace the filter and fill the transmission with new ATF (the TH400 requires six quarts). Do not put the bolts back on too tightly, as the gasket can become damaged. Six to 8 foot-pounds should be plenty. If no torque-wrench is available, just put them on as tight as you can by hand, and then turn them 1/2 revolution.
  4. 4
    Inspect the cooler lines. The number-one killer of automatic transmissions is heat. If the cooler lines that come from the radiator are damaged or leaking, it might be necessary to replace them. These items can also be found at the local parts store.
Posted on Apr 05, 2013
keylempi404
  • 79 Answers
SOURCE: We have a small leak
In my '98 Southwind the tanks are visible in the very back of the basement. I haven't figured out how to access them but I'm afraid it will involve cutting through the corrugated panels in the 2nd from rear basement compartment (right behind the holding tanks)
Posted on Nov 04, 2014
  • 1381 Answers
SOURCE: How to check check engine light on1994 fleetwood southwind rv with scanner
It should be on the left side of the steering column just after it enters the dash. It may be bundled in with all the other wires in the harness making it hard to see. It also may have a dust cover on it. If you are looking for the connector to be mounted on a bracket this may be the problem. Don't look for a bracket, look for a loose connector.
Posted on Feb 23, 2016
I have a 1992 Southwind Fleetwood Ford Chassi need a New winshield Washer Holding tank 3 E7HT-8C045 wher can I find it. Thanks Jack
This seems like a Ford engineering number. Each Ford part has at least 2 numbers. The over counter part number is a common reference that is what parts are sold by. The engineering number is an internal number that is used in production. Some Dealers can reference the Engineering number and generate a Ford part number so that a price and order can be made.
If a leak is the problem, a product called "JB Weld" should seal against wiper fluid.
Jul 11, 2017 | Ford Cars & Trucks
Wiring diagram 1992 Fleetwood southwind motorhome complete wiring scamatics
Go to Fleetwood's site at the link below, and select model and year to download the manual. If it does not have wiring schematic, contact Fleetwood for assistance. RV Owners Manuals
Oct 27, 2016 | Cars & Trucks
I have a 1992 fleetwood southwind motorhome. My problem is im not getting fuel to my generator, I tested the pump and it is working correctly. I followed the fuel line under the unit and up to the I
Try tracing the fuel line from the tank. Look for a connection to what looks like a tin can. If you find it, this is a primary fuel filter. These should be changed about every 50,000 miles. This filter stops all the junk from the tank from entering the fuel line. When it plugs up, it will completely stop the flow of fuel. Be sure to remove the gas cap to relieve pressure, before removing the filter. A new one cost about $15.00
Good luck and Merry Christmas, Bill
Dec 18, 2014 | Cars & Trucks
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Rv 1988 southwind chevy 454
where can i find the fuel pump on a 1988 fleetwood southwind
Aug 15, 2011 | 1989 Chevrolet C/K 3500
We have a small leak (drips) on the rear end passenger side of our 2001 Fleetwood Southwind. Where are our holding tanks located?
Does this leak have a color to it? Take and dip your finger in it and put it on a clean white piece of paper. What color do you see?
Regards, Tony
Apr 21, 2011 | Ford F-250 Cars & Trucks
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
