Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Wont start turn key and get one click new battery
  • 608 Answers
Check the starter solenoid
Posted on Apr 11, 2011
1996 caddy wont start some power
THE STARTER SOLENOID CAN BE DEFECTIVE AND GIVE THIS PROBLEM. OFTEN WHEN IT IS DEFECTIVE IT WILL MEARLY GIVE A CLICK WHEN YOU TRY TO START.
May 04, 2015 | Cars & Trucks
My car wont start i installed new batterry but it wont start when i clicking ignition key
Does the new battery turn the motor over? Sounds like bad/dirty cable connections...
Jan 28, 2013 | 2008 Pontiac G5
06 pontiac grand prix wont start no clicking when you turn the key over even jump starting the battery, has dash lights & radio & parking lights. battery tested good. put a used starter & altinator on
Used parts such as starters and altinators don't last. It might **** but it sounds like you need to buy a new starter,altinator, and battery. Or just start with buying one at a time.
Dec 06, 2011 | 2006 Pontiac Grand Prix
1993 Dodge Dakota repairs. Battery is charged and new when I turn the ignition switch to start there is a click click click click Etc the engine wont turn over. What can I do? Thank You!!!
I have a 93 dodge dakota pick up. When I turn the key I get nothing, The radio and the lights work fine. I had starter checked and the battery changed, It will run if you push it to start but not with the key.
May 20, 2010 | 1993 Dodge Dakota
1999 dodge caravan doesnt start
1999 Dodge Caravan wont start new battery,new starter,nothing but clicks when key is turned on continues to click when key is off could this be the relay switch checked power to starter starter is energized
Apr 13, 2010 | 1999 Dodge Caravan
Car wont start key turns new starter new battery no click
check the nuetral safety switch and the ignition switch under the column not the key tumbler assembly
Jan 21, 2010 | 1996 Dodge Stratus
MY 97 DODGE STRATUS WONT START, ITSGOT POWER AND WEN I TRY TO START IT I ONLY GET A CLICK NOISE, NOT THEDEAD BATTERY CLICKING NOISE JUST ONE CLICK AND THATS IT. I HAD STARTED IT TWENTY MINUTES PRIOR TO...
i believe if you remove the steering wheel upper and lower covers, there will be a button to push to allow the removal of the key..as for the no start, the battery light is on because of the alternator. Its faulty. the clicking sound could very well be the starter not having enough power reaching to turn it over again unless you put a power pack on it...try a brand new battery, test the alternator and removed the key..it is possible the the key not shutting off the way, is drawing power from the battery not allowing to start that way, causing what they call a "parasitic drain". charge battery, remove key. try that
Nov 07, 2009 | Dodge Stratus Cars & Trucks
94 z wont start
You will have to check, at the starter, for power to the SMALL wire on the starter solenoid (which is on the starter) when turning the ignition switch to start.
If there is power to this wire ( usually purple ) and power at the LARGE cable ( from the battery ) at the starter end.....you need a starter.
If you do not have power at the small wire at the solenoid with the key in start position and battery power is OK.....check the safety neutral switch.Moving the shifter around a little can sometimes allow the car to start if the neutral switch is worn.
A new battery does not always mean a fully charged battery.
Try a boost from another car before testing the starter for power.
The battery cables need to be clean and tight....and check the ground to the engine as well.
Everything else may work OK with bad connections,they don't use the power the starter needs to turn the engine over.
Sep 08, 2009 | 1994 Chevrolet Camaro
93 Saturn wont start, battery,lights,all good
There's a relay that's under the dash. keep turning the key until you find what's clicking then replace that relay, the car should start.
Aug 01, 2009 | 1993 Saturn SC1
1991 Dodge Staelth Wont Start
did you clean the battery connections? some corrision may cause your problem
Dec 24, 2008 | 1992 Dodge Stealth
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
