Question about Danby DWC3509EBLS Wine Cooler
My danby wine cooler is not cooling. I'm wondering if there is some easy way to fix this
  • 3 Answers
SOURCE: wine cooler noise
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Jan 28, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
SOURCE: Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Posted on Jul 22, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
SOURCE: E4 Code
Between phone calls to danby and my neighbor, we fixed this problem. My E4 was on the left (lower chamber). If you have one on the right it is the upper chamber. The E4 is a defrost sensor that can be ordered from Danby's distributor (call Danby for the one in your area). The part and shipping were around $30.
If your E4 is on the left...
- remove the top shelves
- open the cover inside the cooler above the digital read outs (the top unscrews)
- inside is were the repacement sensor plugs in
- replace the one with the long cord
- run the sensor down the back to the lower chamber
- replace all covers and parts
If the E4 is on the right...
- look on the right hand wall for a black plastic grate, the sensor is under this grate
- replace the sensor (simple plug and play)
- replace the racks.
Please pass this on, it was a ***** to deal with Danby and I nearly trashed the cooler out of sheer frustration.
Posted on Jan 01, 2009
Why is my Danby wine cooler heating up rather than cooling down?
Check out our Danby wine cooler repair video. Hope it helps.
Jun 27, 2015 | Furniture
Danby DWC166BLSRH is not cooling. Fan is on and a clicking sound comes on, and compressor is very hot but will not cool.
I have the same problem. Mine probably needs refrigerant so it's a safe bet that yours does too. I'm going to order some and fix it, then update.
Aug 19, 2012 | Danby DWC283BLS Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
I am looking for the cooling fan for a Danby Silhouette DWC512BL-1 wine cooler. A google link took me to your site but I don't see any links to Danby parts.
As I have worked on a few ELECTROLUX wine coolers and they do not have a cooling fan for the inside of the unit are you speaking of the one under and in back of your cooler if so then it is a condenser fan motor it will be 110v and your local appliance store should be able to order one close enough to work in design and rotation of it. Hope this helps.
Apr 09, 2011 | Danby DWC513BLS Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Loud noise
The compressor fan is making the noise and causing overheating as well. Easy fix. Call Danby with model # and they can figure out correct fan. Part will cost around $10 and is easy to replace. Plug and play with screws. Good luck
Apr 21, 2009 | Danby Silhouette DWC512BL Wine Cooler
Danby wine cooler model dwc172bl thermostat replacement
Once I figured out there were black plastic caps covering the screws holding the inside back panel in place, it was an easy fix. The cooler is now up and running. Thank you for giving me the $10 incentive to figure it out myself.
Jan 18, 2009 | Danby Silhouette DWC512BL Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Danby DWC3509EBLS Wine Cooler Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
