Question about Reliance & 50gal Electric Water Heater
New water heater will not heat - Reliance & 50gal Electric Water Heater
Water heater has to be full of water before power is turned on or elements will burn out.
If upper element is burned out, then no hot water.
Lower element burned out, not much hot water.
If tank has 2 elements, it is 240V. Water heater circuit may not be delivering 240V. Test for 240V at connections.
Open following link for troubleshooting electric water heater.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 11, 2011
NEW WATTER HEATER MAKES A HUMMING /WHISTLING SOUND
Factory-installed heat traps can cause this problem:
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
Remove heat traps, or heat trap inserts, or heat trap nipples.
Make your own heat traps, and save 4-9$ per year, using flex copper connections, or reconnect pipes in heat-trap configuration.
Always insulate pipes.
With electric heater, pipe insulation can run all the way to tank.
With atmospheric-vent gas water heater, the pipe insulation cannot obstruct air intake at draft hood. With power vent gas, the pipe insulation can run all the way to tank.
Mar 10, 2013 | Water Heaters
Do I need to use the heat trap nipples on my new Rheem electric hotwater heater, I am pressed for space Thanks
Rheem residential electric water heaters appear on following page:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
New water heaters are made with heat trap nipples pre-installed so the product meets industry energy standards.
Sample Rheem manual says: 'All models equipped with heat traps.'
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 31, 2011 | Rheem 38 GAL ELEC SHORT Water Heater 6YR...
I am not getting very hot water for my shower. I turned uo the tempreture and now the temp is fine. This happened before about a year ago. Do I need a new water heater? The heater is from 1998
The heating element sounds like it's going out. With you turning the temperature up, this will increase your power bill. The water heater will heat up until it reaches that temperature. Tankless water heaters are a good option if you are willing to pay the expense. But your heater sounds like it could just use new elements.
Jun 19, 2010 | Water Heaters
We just installed a Rheem 50 gallon water heater. When you use any hot water a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating cycle...
Every electric water heater I have ever installed makes a low hum while heating. I believe this is a combination of the current going through the elements and the minerals in the water cooking on the elements. That is the best explanation I have. Hope this helps.
May 11, 2010 | Rheem 81VP6S/430126 Water Heater
How do i change the element in my water heater
The most important step is to turn the power off. If you still have the manual it is the best to follow the instructions provided in a book.
If not, learn about electric water heaters, how to test the heating elements, how they work and are they OK, than follow the instructions:
Once the power is off, turn the water supply off, attach the hose and drain the water heater.
Unscrew the terminals from the heating element and unbolt the elements from the water heater.
New heating elements has to be with same specs as the old one.
Before turning the water heater on it is VERY IMPORTANT to refill the tank.
Mar 21, 2010 | Reliance & 50gal Electric Water Heater
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
Takes a long time to heat water. Brand new Ge 50 gallon water heater. Once heated it right temp,just a long time to heat it and then won't maintain hot water. Is gas line to small? 3/8 copper line. Thanks
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Feb 27, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Reliance & 50gal Electric Water Heater  Logo
88 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
