Question about General Filters 1042-LH Humidifier
There is no water going into the humidifier, make: Generalaire 1042
    Genius:
  • General Filters Master
  • 1,033 Answers
Hello, first thing is check is the strainer going into the solenoid valve for sediment, if there is clean the strainer and reinstall. If the strainer in clean the check if you are getting 24 volts to the solenoid valve, if you have voltage and the solenoid does not let the water thru replace the solenod valve.
Posted on Apr 09, 2011
Leaking at base due to too high of pressure or defective evaporative filter?
Humidifer FAQ's - General Filters, Inc.
www.generalfilters.com/support/faqs/humidification.html
I already have a GeneralAire® 1042 Humidifier installed, but have a 4,000 square foot home. Should I ... Can't I simply clean my Vapor Pad instead of replacing it? Where do I find ... I am seeing a very slight water leak coming from the bottom of my steamhumidifier. What do I do ... Legacy 1137 = 21 GPD / Up to 3,000 Sq. Ft.
GeneralAire® Legacy 1042 and 1137 Humidifiers - YouTube
? 3:22
https://www.youtube.com/watch?v=IM6IXVcjEdU
Jun 27, 2013 - Uploaded by GeneralAire Inc
GeneralAire® Legacy 1042 and 1137 Humidifiers - How to change the vapor pad .... Evaporator Pad (aka filter) change on aGeneral Aire 1042 ...
[PDF]General Aire Humidifier Owners Manual - On Time Mall
Jan 16, 2016 | GeneralAire Legacy 1040 Humidifier...
My generalaire humidifier leak from the bottom , I have check the hose and inside all ok
Did you check the orifice inside the supply water tube? Sometimes the orifice can come loose and allow to much water inside the humidifier.
Feb 06, 2014 | General Filters 1099-LH Humidifier
Frequent knocking noise coming from General Aire 1042 LH humidifier
Hello, it depends where the sound is coming from,if it's in the supply water line it could be caused by water hamer or the inlet side of the solenoid valve might be clogged up with sediment. Water hammer is when the solenoid closes under high water pressure and a water hammer arresters should be installed. If the sound is coming directly from the solenoid valve and is more of a chattering sound then there is a loose low voltage wire or the solenoid is going bad. If you disconnect the power to the solenoid and the chattering stops then solenoid must be replaced as it is the cause of the noise.
Mar 17, 2011 | General Filters 1042-LH Humidifier
Wiring a generalaire 1042 humidifier to a goodman furnace,when there are no terminals marked hum
24 VAC HUM
The yellow wire connected to the I.D. Blower pressure switch
is powered anytime the pressure switch is closed and provides
24 VAC humidifier control. Remove the yellow wire and connect
the supplied brown jumper wire to the pressure switch
terminal. Reconnect the yellow wire to the "piggyback" terminal
on the brown jumper and then connect the 24 VAC line of the
humidifier to the stripped end of the brown wire. Using a wire
nut or a field-supplied quick connect terminal can make this
connection. The wiring must conform to all local and national
codes. Connect the COM side of the humidifier to the B/C
terminal on the furnace control board (or to the COM side of
the 24 VAC transformer). DO NOT CONNECT 115V HUMIDIFIER
TO THESE TERMINALS.
Feb 21, 2011 | Humidifiers
No water is making it into the humidifier. Loosened the nut of the water supply and there is water going to the unit
Hello, there could be sediment built up at the saddle valve outlet which is preventing water from flowing to the humidifier, If that is clear than the saddle valve must be replaced.
Jan 25, 2011 | General Filters 1042-LH Humidifier
My 1042 L General humidifier is not putting moisture in the air eventhough water is getting to the filter
General 1042-L not putting moisture in the air. Water valve is open and getting to the filter. The unit is clean.
Dec 01, 2009 | General Filters 1042-LH Humidifier
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
General 1042
The 1042 has a valve that operates on 120 VAC. The 1042-LH has a valve that operates on 24V.
Oct 13, 2007 | General Filters 1042-LH Humidifier
General Filters 1042-LH Humidifier Logo
496 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
