Is stalls while I'm driving it, and when my foot is applied to the brakes sometime
    Problem Solver:
  • 17 Answers
Laptops are not automobiles. They do not have brakes...
Posted on Apr 09, 2011
'96 Mystique 2.0 trouble with idle. replaced idle mixing valve. I don't get any codes, I have to shift to neutral at a stop sign or light to keep from stalling. It gets real rough almost a lope.
troubles at lights may very well mean a vacuum leak from a faulty brake booster
test by stopping and then applying the park brake and taking your foot of the brake pedal
you can do this test in the garage
start the engine , apply the park brake , place in drive
if it idles alright , put you foot on the brake
if it plays up , replace the brake booster
Jan 24, 2017 | Cars & Trucks
Why won't it shift into park sometimes?
  • Push down brake pedal with foot
  • Shift into park
  • Apply emergency brake
This sequence should eliminate the problem
Dec 19, 2015 | Dodge 2010 Grand Caravan SE
Stalling troubleshooting
run fault codes to check for electronic problems (TCM). If this problem only happens when the foot brakes are applied check for brake booster vacuum problem. Remove vacuum line and blank off and apply the brakes to see if the engine stalls at idle.
Jul 22, 2014 | Ford F-150 Cars & Trucks
My 2004 jeep grand cherokee is stalling when driving slowly or stopping?
simple test
ut the hand brake on and start the car
idling ok --good --apply the foot brake-- idling bad --replace the brake booster
check for other vacuum leaks including transmission actuator hose , dash vent controls hoses
May 09, 2017 | 2004 Jeep Grand Cherokee
2005 chevy cobalt stalls when foot is off the gas
u may have a brake booster leaking vacum when u apply the brake its useing vacum from engine see if u can hear a hissing sound when apllying brake if so thats ur problem
Oct 02, 2012 | 2005 Chevrolet Cobalt
I HAVE A 1998 CADILLAC CATERA V6 AUTOMATIC ENGINE DIES IN DRIVE
Yes, most likely a fault in the auto transmission, and the car has shut itself off to prevent further damage.
Aug 03, 2009 | 1997 Cadillac DeVille
2000 grand cherokee v8 struggles to start and stalls when slowing
i think your exhaust might have a leak which is heating up your oil when this happens the engine suffocates and wants to die.
Dec 02, 2008 | 2000 Jeep Grand Cherokee
87 honda accord
Probably a bad torque converter lock up solenoid...
Try starting it in neutral, and putting it in drive without your foot on the brake (I know the car will take off in quite a hurry if it doesn't stall but it's an easy way to check for this)
If it doesn't stall, apply the brakes, and if it stalls then, it definitely is a bad lockup.
I don't know if you're familiar with the torque converter function/operation, but where it is a fluid (liquid) and not solid coupling with the engine, lockup is used at certain road speeds/engine RPMs to get rid of the power loss that always occurs between the pump and the turbine of the torque converter. It mechanically (through transmission oil pressure) locks both parts of the converter together so it then acts like the engine crankshaft is bolted right to the input shaft of the automatic transmission.
But, as you might imagine, this system has to unlock the converter when you apply the brakes for the same reason applying brakes without the clutch on a manual transmission stalls the engine.
Bad lockup solenoid will cause this to happen... The converter stays in lockup and as soon as you try to stop the vehicle, you also stop (stall) the engine.
It also might be something else but I'd say I'm about 90% sure on this one.
Aug 20, 2008 | 1987 Honda Accord
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
