Question about IBM Wheelwriter 30 Typewriter
All Keys Beep
I inadvertently hit a combo of keys while typing. Now the typewriter makes a beeping noise at EVERY keystroke. How do I undo this?
  • lisa_halbig Oct 07, 2008
    I got an error message 101 88, with what looks like an e-mail icon on the lower left corner of the display. What does this mean. It just keeps beeping with every keystroke, and not typing anything.
  • IBM Master
  • 3,594 Answers
PRESS CODE AND "S"
DigkyO
Posted on Aug 08, 2008
SOURCE:
The keys seem to have froze up. I can't type at all, none of the keys work. The buttons beep at me instead of typing.
There is a very good chance that there are broken wires in the harness going to the print head. You'll need a tech.
DickyO
Mar 03, 2011 | Olympia Mastertype 3 Typewriter
When turning the typewriter on it goes beep beep and when pressing the keys it will not type
Re install the printeheel, check forv debris in that area, check to be sure no keys are stuck down. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Feb 17, 2011 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 30 Series II-What is the button combo to disable the keystroke beeping? I do not have the manual.
http://www.lexmark.com/publications/pdfs/2007/typewriters/Wheelwriter-30.pdf
Hold down the CODE key and press the s key to turn off sound.
Jul 22, 2009 | IBM Office Equipment & Supplies
IBM Wheelwriter 3 not printing letters ( keystrokes)
The print solenoid cap is probably broken,they are available but a little yricky to install.
DickyO
Jan 26, 2009 | IBM Wheelwriter 30 Typewriter
Writer beeps w/keystroke and does not type.
You are probably in a format mode that was set up for 12 piych printwheel. Install a 12 pitch pwintwheel or exit the format mode.
DickyO
Dec 31, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5 --cant set the right margin
A beep 5 spaces before the margin is all you are suposed to get, no lock or stop just a beep
Dec 07, 2008 | IBM Wheelwriter 30 Typewriter
Need directions to store keystrokes in Xerox 610 Memorywriter
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
Nov 12, 2008 | Olympia Mastertype 3 Typewriter
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
Beeping sound when powering unit on
Have you simply pushed the carriage back to the middle? If it is like the ML100 (it looks the same) you can just push it over ...with the pwoer off. Then put in you new ribbon. And this time, when you turn it on, it is the new ribbon that hits a switch on the underside of the keyboard, located to the upper left. If you do not have a ribbon installed, it will travel all the way to the left, and beep, beep, beep, beep. ,,,, The switch is hit with the ribbon housing.
Jun 25, 2008 | Brother ML-300 Typewriter
IBM Wheelwriter 30 Typewriter Logo
118 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
