Question about Lavazza Espresso Point Capsule Machine
I have a Lavazza Point Expresso Machine and it started leaking water out of the front. I believe it needs a gasket, but can't seem to get the parts to come off to get to it. I have used an Alen Wrench, but that doesn't seem to help. ANy suggestions, or could you recommend a service place for me to bring it. I live in Scottsdal, AZ. I need help...I am going through withdrawl!!!! Thanks! Jodi
    Problem Solver:
  • 16 Answers
When replacing the o-rings inside the boiler the operation should be carried out by a certified technician for these machines. When the boiler is dismantled it is recommended that all o-rings and springs in the boiler be replaced as these are ware parts. When the boiler is apart this is also an opportune time to do some manual cleaning to the internal parts. This is an easy task but as I said before must be carried out by a certified technician. Special tools not readily available to homeowners are required to rebuild the boiler once dismantled. I am sure there are many repair facilities around but location wise I am not sure. I have heard that espressozone.com are nice and will do repairs. Perhaps try them. You may also try contacting a lavazza rep and they may be able to point you in the right direction.
Posted on Aug 04, 2011
I have lavazza expresso pointe machine. I put in cartridge and select cup size and water keeps going. It doesn't stop so cup overflows and ends up just water flowing thru
need to remove the back cover, which has a few screws in the bottom left corner is a round and white plastic device that is said meter. Disconnect hoses from it and open it. Clean it well and then close it and put in place. Should be fine!
Jan 06, 2014 | Lavazza Espresso Point Capsule Machine
I have a Lavazza espresso point machine and I need a wire spring to replace the old one which broke. The spring helps close the "doors" onto the capsule when you introduce it in the machine....
Which of the Jaw spring is broken? Left of right, is essential to know, they are not the same. Where are you located? I have some parts or I could give directions to a dealer near your home. Guru.
Sep 23, 2011 | Lavazza Espresso Point Capsule Machine
LAVAZZA EXPRESSO POINT THE RED LIGHT BUTTON KEEPS FLASHING CONSTANLTY, WHEN I MAKE THE COFFEE IT SQUIRTS OUT ALL OVER THE PLACE, IT DOENT HAVE A NICE FLOW LIKE IT USE TO
Causes:1- the 130 deg thermostat is open. 2- working thermostat, 104 deg, defective, allowing temp to rise.3- the machine becomes hot because the water valve is stock open. machine needs to be sealed so not to allow water to boil.Water boils at 100 deg Celsius. 4- valvolino or o-rings are worn out and leaking. You need a repair shop.
Guru
Sep 21, 2011 | Lavazza Espresso Point Capsule Machine
Buttons don't work
contact me @ www.lavazzarepair.com
Oct 25, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza Expresso Point Machine - not able to steam the milk - that part of the machine has no steam capabilities
The wand is clogged try reaming out with a small thin paper clip straighten out and insert thru the hole in the tip of the wand contact me www.lavazzarepair.com
Oct 24, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza expresso machine
Is the machine blowing fuses? Your electronic keypad, or circuit card may be damaged.
If you need service you can call 781-393-2929
we are an authorized lavazza distributor and repair center.
Jun 02, 2009 | Lavazza Espresso Point Capsule Machine
Heating element on an lavazza expresso machine
you can call this number they will help you with your problem
1-866-526-6204
Apr 15, 2009 | Lavazza Espresso Point Capsule Machine
Lavazza point espresso machine
Sounds like you're in need of a new chamber and possibly some thermostats. For service you can call 781-393-2929, we are an authorized Lavazza distributor and repair center.
Jul 23, 2008 | Lavazza Espresso Point Capsule Machine
Lavazza Espresso Point Capsule Machine Logo
667 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
