Question about Yahoo Messenger
Hi when I want join to a conferance the system gime me a error message that I am not autorized to join what is the problem?
  • 22 Answers
That's means admin already close the conference. Try to remove ur messenger and install it again.
If problem is still there install your whole operating system and then install YM
Thanks
Arnob
Posted on Apr 09, 2011
Why does system seem to reboot on its own?
check that you allocate a fix IP in the router. At times it could be re-allocated to a dynamic IP and this cause the failure to maintain the connection.
Oct 24, 2014 | Polycom HDX 7002 XLP HI DEF-VIDCONF Video...
Tip
Trace invisible contacts in yahoo mesenger trace invisible contacts in...
Trace invisible contacts in yahoo mesenger trace invisible contacts in yahoo mesenger
first method: Voice Chat Method
1. Double Click on the user whose status you want to check.
2. Click on “Voice” icon on the toolbar, or select “Contact” menu and select “Enable Voice Chat” .
3. The deciding part… there are 2 possible results:
a) If the user is offline, you will get this message: “Internal server error. Cannot obtain voice token to start voice chat.”
b) If the user is invisible (actually online), you will see the Voice Toolbar.
second Method: Conference Invitation
1. Right Click on the user whose status you want to check.
2. When the menu appears, select Invite to Conference.
3. A window will appear. See at the right pane, the username you selected will be there. Now, click Invite.
4. The deciding part… there are 2 possible results:
a) If the user is offline, you will get this message: “None of the users in the invite list are available to join the conference. Please try at a later time.”
b) If the user is invisible, you will get a window similar saying: “You are now logged into voice conference
on Jan 11, 2010 | Computers & Internet
I need a card for conference calls. where can i get one and for how much.
Conference calls can be made for free.
To set up a conference call:
  1. Dial 305 848 8888
  2. Select "Set up a Conference Call" and follow the prompts.
You will create a password and will be given a 10 digit code.
Distribute the code, time of call, and dial in number (305 848 8888) to all conference call attendees. You may use the access code for any future conference calls as well.
To join a conference call:
  1. Dial 305-848-8888
  2. Select "Join a Conference Call"
  3. Enter the pin
Nov 14, 2013 | magicjack.com
How to create a conference call on nokia 6600
Hi there!
To make a conference call you can do the following:
-Make a call to the first participant -To make a call to a new participant, select Options>New Call. -Type in or Search for the number of the second participant and press ok. The first call is automatically put on hold -When the new call has been answered, join the first participant in the conference call. Select Option>Conference -To add a new person to the call, press Option> New Call and search for the next participant and just select Option>conference again
Hope this helps!
Apr 29, 2011 | Nokia 6600
I can't use voice in conference, says I am not authorized to join this conference and when I go in private chat the talk button won't even work
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Jan 28, 2011 | Yahoo Messenger
How do we arrange a conference call?
While on a call, press conference or transfer button(will put first call on temporary hold). Make call to next party, talk to party, press conference button to join all callers. Same procedure to add more parties up to 8 total.
Also, if you use transfer button to start conference call you can use transfer button to join all parties.
If you use conference button to start conference call use conference button to join all parties.
Dec 15, 2010 | Panasonic KX-T7130 Corded Phone
Whenever i try to join a conference through yohoo massanger, a message comes"you are not authorized to join the confeence"
whenever i try to join a conference through yohoo massanger, a message comes"you are not authorized to join the confeence"
Nov 11, 2010 | Yahoo Messenger
I have problem with voice calls on my yahoo id
yahoo chaat room you are not authorized to join the conference voice error my id/Bad_Boy_0175@yahoo.com
Aug 09, 2010 | Yahoo Messenger
Yahoo messenger 9.0/os xp pro
what operating system do you have yahoo messenger works best in xp pro any other operating system won't have all the working features if you have xp pro then uninstall all yahoo related then reinstall after you reboot you system after all files are uninstalled.
Oct 03, 2008 | Yahoo Messenger
Yahoo Messenger Logo
49 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
