Question about Toro Garden
I have a Toro 20334 self-propelled mower. The arm spring on both of my rear tires have been bended. I tried to replace the arm spring by remove everything up to the Arm Pivot. However, no matter how hard I tried, the Arm Pivot just won't come off. I even try to use a pry bar to get the Arm Pivot but it just never came off. Am I missing something? Can someone please help me with this issue? Thanks
  • 65 Answers
SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Posted on Jul 25, 2009
  • 77 Answers
SOURCE: my toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Posted on Aug 09, 2009
  • 67 Answers
SOURCE: The rear wheels on my 22" Husquvarna mower, self propelled
sounds like the reinforcement bar across the back is broke or missing
Posted on Sep 01, 2009
  • 133 Answers
SOURCE: how do I replace the belt on my toro model 20334
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from comming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Sep 03, 2009
Dolfoff
  • 148 Answers
SOURCE: how to remove and replace rear wheel tire on my
Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
FRONT
1) Remove plastic hub cab with a screwdriver around the outer edge.
2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
REAR
2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
3) Slide the remainder of the wheel assembly off the axle.
4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
As was mentioned before, doing one at a time will help keep the parts in the proper order.
Hope this helps!
Posted on Sep 30, 2009
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro self-propelled lawn mower: throttle doesn't work, I suspect I may have mis-connected the spring and rod connecting the swivel plate to the lever arm. Does that make sense to anyone?
Yes it makes sense. I was working on a throttleless one and it would not come up to speed, I had hooked it up to the wrong side of the shaft, or conceptually, the pivot point. It was doing the opposite of what it should have. I suggest taking a really close look at the attachment piece looking for wear or rub marks to indicate which hole it should be in.
I hope this gets you going.
Aug 09, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Spring which holds the rear discharge "gate" tight
Go jackssmallengines.com browse around and you find what you seek. Good Luck...
Jul 19, 2011 | Toro Power Lawn Mower
Pull cord wont retract on my toro self propelled lawn mower
Sounds like a spring problem. Remove starter shroud, try pulling it and see if it works. If the spring isn't broke you may have to take another rap on the rope to gain more tension, or spray mechanism with some wd to free it up.
Sep 28, 2010 | Toro Garden
Aug 18, 2009 | Garden
Self-propelled feature does not work at all! Any suggestions?
You might have a broken belt to the self propelled or a broken spring or whatever engages the self propel. Take off the cover and see if anything is broken or missing. Have someone engage the self propel while you are watching and see what is going on.
roundo4
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
135 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
