Question about Refrigerators
The refrigerator periodically leaks water onto the floor from underneath. This problem started several weeks ago. We have looked for a leak but have been unable to find one so far. Could it have a condensation tray that is overflowing?
    Genius:
  • 1,196 Answers
Water from the bottom of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan, or a clogged defrost drain pan.
I will advice you check these area to fix the problem.
Posted on Apr 09, 2011
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Refrigerator leaks onto floor?
when fridge goes into deffrost water from defrosted ice should drain to underneath fridge. drain could be clogged.... or ice has buily up over drain hole.
Sep 01, 2014 | Refrigerators
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Rf266. Water collects under the bottom drawer of the refrigerator and results in leakage underneath onto the floor
Can you click HERE and read and or watch the video's so you can get an idea of what needs to be done behind the rear panel of the freezer to unblock the condensate drain Leaking Refrigerators.
Thanks, John Tripp Appliance 911
What is the model number?
May 01, 2014 | Refrigerators
Water leaking periodically (1x per week) from bottom of refigerator. Water clean and spreads on the floor about 1 to 1.5 feet in diameter.
drain pan underneath needs to be emptied. it should slide out but you may want to check for screws or bolts.
Jan 31, 2011 | Electrolux Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Sep 28, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Water comes from under drawers on fridge side, leaks onto floor
If leak continued then you must have a faulty cut off valve. Check and tighten valve. Also, check the hose that runs underneath the fridge for cuts or holes.
Jul 12, 2009 | GE Profile PFS22 33" Artica French Door...
Leaks onto floor
your defrost drain is stopedup if its a sxs its in the back bottom of freezer side if its a top mount its behind the back over in the freezer remove and use hot water and blowdryer you will see a little drain tube under the evap coil
Jul 05, 2009 | Frigidaire Gallery Series GLRT218WDZ 30"...
Refrigerators Logo
276 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
