Question about Brandt Washing Machines
Motor don,t start - Brandt Washing Machines
    Brigadier General:
  • 6,277 Answers
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Apr 09, 2011
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
Motor humms but wont engage
The start capacitor or start winding has gone bad. Or bearings are dry.
Don't run motor if it does not rotate full speed or motor will overheat and go bad.
Replace or repair motor.
Each motor has 2 winding circuits.
Start winding and run winding.
Both windings receive power same time.
Start winding has capacitor that releases sudden burst of electricity that starts motor rotation. Kind of like low speed on transmission.
Run winding then brings motor up to speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Nov 07, 2012 | Pool & Spa
My ninja blender motor starts but the blades don't turn
As stated earlier it could be the shaft needs lubing, remove the bottom part of the blender blade... the rubber thing that engages on the motor. I started with WD-40 and worked some lithium grease into it. Spins like new now.
Jun 18, 2012 | Blenders
RAZOR 500 BATTERY CHARGE MOTOR DON'T START OR EVEN CLICK DON'T WANT TO SPEND LOTS OF MONEY HOW CAN I CHECK THE MOTOR
Get a automotive battery charger that has 10 amps and hook it up to the motor. If the motor spins the motor is good. Just had to do this myself. Thought the motor was bad on ours and tested it found out it was good. Good Luck!
Jun 03, 2012 | Razor MX500 Dirt Rocket
Hyosung GV 650 wont start. Battery is fully charged and starter don't even click when trying to start?
This will be either the starter solenoid is faulty or the starter motor needs replacing.Have the solenoid checked before removing the starter motor.
Mar 21, 2012 | Hyosung GV 650 Aquila Motorcycles
The ac unit is blowing cold air on th inside but the motor fan on outside unit is not working
The outdoor fan motor can fail and also the start capacitor that helps it start can also fail...if the compressor is running then the motor should be getting power...
Change the cap. first and if that don't do the trick, then change the motor...
Heatman101
May 28, 2011 | Heating & Cooling
Dryer gives heat but don't run you don't hear the motor running
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 23, 2011 | Dryers
My front wipers do not work, the washer on the front and the rear wiper works fine, they are all on the same thing
HI. This is a possible motor issue. To confirm, use this procedure. it will help isolate the actual issue at hand.
1.Make sure the battery has a strong charge and is in good condition. Use a voltmeter to get a reading if necessary.
2.Connect a jumper wire between ground and the wiper motor. Turn the key on but don’t start the engine. Turn the wiper switch on. If the motor works, check for a corroded or loose ground connection.
3.Turn on the car key but don’t start the engine. Turn on the wipers. Check for voltage at the wiper motor with your voltmeter. If you get a good voltage reading, turn the key off and disconnect the motor from the wiper linkage.
4.Move the wiper arms by hand. If they are stuck, you have found the problem. If the wiper arms move freely by hand, go to step 5. If voltage is not reaching the motor go to step 6.
5.Remove the wiper motor by disconnecting the plug and removing the bolts using a wrench or ratchet. Use a pair of jumper wires to connect the wiper motor directly to the battery. If the motor does not work, replace it.
6.Turn on the key but don’t start the engine. Get a voltage reading across the wiper switch. If there is voltage, use a jumper wire to bypass the switch, if the motor works now, replace the switch, otherwise go to step 7. If there is no voltage at the switch, go to step 8.
7.Check for continuity at the wire between the switch and the motor. The wire could be loose or disconnected.
8.Check the wire coming from the fuse panel to the wiper switch. It could be disconnected or loose.
Nov 23, 2009 | 2004 Jeep Liberty
Driver windshield wiper does not work
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Oct 10, 2009 | 2002 Toyota Highlander
Washing Machines Logo
70 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
Harjeet Singh
gcharal
Level 1 Expert
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
