Shortly after installing a new drum all pages from the printer have a column of color dots (like tiny "mirror image" coma's) sets of 3, red/green blue; each 1/4 inch apart, followed by a 7/8 inch gap, them repeat of the dots,down the page center. 3/8 inch to the right of these dots is a washed-out faint black line 3/8 inch wide...top margin to bottom margin. Any ideas, please?
  • 4 more comments
  • carym885 Apr 09, 2011
    I am sure you mean well Benjz, but this is a laser printer. It has no ink cartridges; no carriage, no carriage door. It does not require a "callibration" and, as it is not an ink jet...a "calibration"is not a possible function.
    The "advice" from benjz does not rise to the level of "insufficient". It suggests efforts which are not applicable to a laser printer and thus cannot even be attempted as it suggests changing devices and performing function which a laser printer cannot do. Specifically, as I told Benjz:I am sure you mean well Benjz, but this is a laser printer. It has no ink cartridges; no carriage, no carriage door. It does not require a "callibration" and, as it is not an ink jet...a "calibration"is not a possible function.
  • carym885 Apr 10, 2011
    Hello PCtech,
    Well..a new drum may or may not fix it...but it will cost $150 just to try...tje precise step I was seeking to avaid, Also the present "new" drum did work flawlwssly for a few day...so evidence suggests that may not be the answer. In giving "Fixya" a try I am willing to pay a modest price for aa acual "fix". In a very real sense. "Buy ya" a new one, is a universal way to achieve an outcome when one does not know a way to "Fix" the present device.
    I will try that step if no one suggests a "fix" rather than a replacement...but even then, I will just buy and try an additional new drum,,,if it problem persists after that next purchase...I will then have two "new" drums and zero working printers...but if I can subsequently fix it, I will have two usable drums as well. I think it likely that I cannot exchage or refund the drum.
    For now, I am still looking for a "fix", please.
    Hello PCtech,
    Buying a new drum costs $150 and may or may not work. The present drum was fine for a few days. Which is why I am first looking for a fix "ie fixya"; and not a "Buy ya"...at least not yet.
  • carym885 Apr 12, 2011
    Good day and thanks for your suggestion,
    In taking the parts out and cleaning, I found one felt roller and one rubber roller with much toner on them in a position that matches with the print streaks. However, after carefully cleaning them, the problem reappeared after only a few pages of print. The two rollers were again coated with toner, It appears that the used toner container (part of the new drum) is leaking used toner onto those parts.
    Thus there seems to be no possible "fix", but rather the "new" drum is defective and must be replaced.
    Best regards,
    Cary
    Best regards,
    Cary
    There was no "fix"...the new drum was defective and had to be replaced. This last suggestion led me to find the defect.
    Best regards,
    Cary
    President:
  • 1,961 Answers
Cleaning will resolve this problem just clean all the rubber rollers of the printer.rubbers which the paper pass through when printing remove any dried/powder inks use a soft cloth moistened with an alcohol .then test print again.good luck
and let me hear how it goes!
Posted on Apr 10, 2011
  • 1,940 Answers
More than likely you got a bad drum, or the drum was damaged before or during installation. Return the drum to the place you purchased it and get a replacement. Be careful to avoid high exposure to light, any exposure to magnetism, pens, paperclips, etc., and take care when installing the new drum to help avoid this problem again. The drum cannot be repaired, it must be replaced.
    Genius:
  • 1,570 Answers
Hi
Please try to set up or add once more the printer and maybe the new drum installed was not recognized by the printer. If not, uninstalling and reinstall the printer driver and set up once more the printer.
If still not work, try to reset the printer.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Posted on Apr 09, 2011
Riso drum prints extra little black dots on page
The solutions on that problem is in the imaging unit like you just have to clean the lens of the camera since tiny dots are dust that is being scnned by the lens during master making process
May 16, 2013 | Riso RZ220 Duplicator
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
Installed TN360 Brother toner and now getting 6 "dots", evenly spaced on the right edge of each paper. The cartridge has been "rocked" and the corona wire cleaned.
More than likely you have some excess toner that is stuck on the image drum, thus the evenly spaced dots down the page. Examine the image drum to see if you see the stuck on toner. Take care not to touch the "glassy" surface of the drum. Use a lint free cloth to see if you can remove the spots. Do not use force as this can damage or scratch the image drum and then you will have scratch marks running down your page. If this does not do the trick you might also have to replace the image drum.
Mar 07, 2011 | Brother MFC-7340 All-In-One Laser Printer
My CP2025 is printing tiny colored dots on my pages...what do I need to do?
You will most likely need to change what ever toner cartridge that is the same color as the dots. So if the dots are pink change the magenta. If they are blue change the cyan. Most of the time these dots are a result of the toner cartridges drum having a pit or similar defect in it. Changing the toner cartridge will take care of this.
Good Luck and Thank You for using Fixya.
Oct 09, 2010 | HP Laserjet Cp2025n Printer
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
Toner specks along the edge of the page
Rev. Gregory.
Its looks like you have a small pinhole, or divot, on a imaging conponent that is common to all four toner cartridges. Remove the drum unit from the prtr and keeping the green handle close to you pull back the shutter which covers the drum, and look for spots of toner at the either end. If you hold the page with the spots on it, with the leading edge centered and touching the drum, it will give you some idea where the edgeis relative to the end of the drum. If you can't see any corresponding spots on the drum surface.
Put the drum unit back into the prtr and allow the prtr to restart, then switch off and remove drum, this will have turned the drum to a new position, and should show any defects. Only expose the uncovered drum to light for a minute at a time, and avoid touching the surface.
Let me know what you find.
Cheers
DeJudge
Sep 24, 2009 | HP LaserJet 2840 Printer
Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Apr 28, 2008 | Office Equipment & Supplies
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
Black spots on my documents Brother HL-1440
Stray dots (on a vertical imaginary line on the page) may not require an expensive drum replacement. In my situation, I simply followed these steps:
(1) Open up the printer, remove the toner-cartridge/drum assembly, and remove the toner cartridge from the drum.
(2) For purposes of reference, place (and center) a sample page of the "offending" output in the bottom of the drum housing, lining up the dots so that the page is turned the way it would have fed through the printer, placing the page generally in front of the shiny green roller surface. Loo, for where any matching black dot or other thing might be sitting on that surface.
(3) Gently roll the green surface's roller with its outside end pegs (without touching the green surface) if and until such a matching dot (or dots) can be found. (Multiple dots might appear along other imaginary verticals on the page, which is to say, additional vertical striping is occurring because there are more instances of "items/dots/garbage" arrayed across the roller on the horizontal, to produce repeat images down the page as the page feeds through the printer.)
(4) Take a Q-tip and very, very, very gently "polish" away the dot(s) you found on the green roller. (I ended up just dabbing the dot I found--which had consistently left a trail of three dots down my pages, in different locations because of the distance the roller traveled relative to the page size--using the absolute least amount moisture to remove it.)
(5) Clean the drum's corona wire by moving the blue plastic slider back and forth, and leave the slider at the far left point.
(6) Reassemble the toner cartridge and the drum and place the assembly back in the printer.
(7) Test.
Worked great for me. Done in around five minutes. No cost, except for the negligible cost of a Q-tip. No time waiting for a new drum to show up, etc.
Oct 17, 2007 | Brother HL 1440 Laser Printer
46 people viewed this question
jasbo
jasbo
