The error message on the monitor shows E 78. When we left the office yesterday, it was working fine. We came back in the morning; it had the error message.
Whats the problems and if I can fix it myself, what do I need to do step by step.
Risograph C1610 Error E 78 - Problem was fixed by re attaching the detached cable inside the top scanner. you have to take apart the scanner on top and re attache the cable and that should get rid of the error
E-78 is model selection error,turn off machine. Hold the 2 arrow buttons in at the same time while you turn the machine on again. You are now in tech mode,press 200 and then green button. Go with the arrow button till you see letter d agains 200. Turn off and turn on again. Let me know if its fixed.E-78 is model selection error,turn off machine. Hold the 2 arrow buttons in at the same time while you turn the machine on again. You are now in tech mode,press 200 and then green button. Go with the arrow button till you see letter d agains 200. Turn off and turn on again. Let me know if its fixed.
Hey willie I need to get some spare parts for riso cr1610-rz290-ez290-rz390 my mail is [email protected] ...Hey willie I need to get some spare parts for riso cr1610-rz290-ez290-rz390 my mail is [email protected] ...
You can't post conmments that contain an email address.
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload. Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Thanks for your question! I'm sorry that you haven't received an answer yet. The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when: 1. the question is unclear, incomplete, or poorly worded... 2. the question is mis-categorized - so the correct experts aren't viewing it... 3. the question requires an answer for something that cannot be explained online adequately... 4. specific training, tools, or equipment are required to avoid injury or death... 5. the Experts that are online simply don't have the resources to answer your question fully... Please feel free to re-work your question if you feel one of these may be the reason. Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well. Normal rates for FixYa are... $ 9.99 answer for one question. $12.99 Live Real-Time online chat or premium e-mail support. $29.99 Live Real Time phone support Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership. Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Your power suplly is blown you can repair if you know alittle about repair can use a soldoring iron. You have to take the back apart and look at power supply. Look for blown caps they show raised tops bubbling on top. If you can't repair I do repair of monitor for the schools where I live if you don't want to try and repair it cantact me I will pay for shipping for parts. [email protected]
Good Luck.
You will have to select corect machine model in service mode 200 , nomaly it is d but you will have to select between 1 and f to find the corect setting or just make sure that your cable is connected corectly
Remove the old mater on drum and clean your master incoder strip and sensor. Look also at your drum clamp and bend the 2 sides of the 2 arms a bit up that goes under the clamp unit so that it can open a bit wider. let me know if you still struggling.
i have riso cr 1610 ,i nead manual serves pleas. thank you
I have the same problem any ideas thanks
[email protected]
E 78
