Question about Poulan Garden
How do you pull the chain break apart on a poulan chainsaw 2150 and repair it.
  • Poulan Master
  • 2,239 Answers
The brake is a saftey item on the saw and should only be repaired by a quailified fitter, however if you should decide to do it yourslf that is down to you, the brake is a so called knee link brake, start by removing the brake from the saw, once removed activate the brake by pushing the hand guard forward untill you hear the brake come on, now remove the allen screw in the hand guard pivot ( do not remove the c clip in the side of the hand guard ), tap the pivot collers out from either side and remove the hand guard, remove the cross head screws securing the spring cover, BE AWARE THERE IS A COMPRESSION SPRING UNDER HERE, eye protection should be worn, with the cover off, pry out the spring, remover the small pin securing the knee link mechanism, using a small punch tap out the roll pin from the other side of the cover that secures the anchor end of the band, it should now come away, remove the cross head screw holding the band to the knee link mechanism. You can now replace the band, refit the the knee link to the new band, re fit to the machine, tap the roll pin back into the cover to secure the anchor end of the band, re fit the knee link pin, re fit the spring ( be carefull ) re fit the spring cover, place the hand guard back on the cover, use a suitable tapperd punch to insert through the hand guard and cover to hold it in place, now pull the hand guard fully back to load the brake, remove the punch and re fit the pivot collers and allen screw. Make sure the brake now functions properley.
Posted on Apr 10, 2011
How much compression should the saw have?
What Causes Too Much Compression on Poulan Chain ...
homeguides.sfgate.com > ... > Other Types of Mortgages
Many makes of gasoline-powered yard tools, including Poulan chain saws, use two-cycle, or two-stroke, combustion engines. ... Pull the rope out and oil it to see if that helps the problem. ... How Much Compression Should a Stihl 066 Have? ... Pull Starter on a Poulan Chain Saw · Oil Pump Removal on a Poulan Chain Saw ...
The Timber Trades Journal and Saw-mill Advertiser
Nov 26, 2015 | GCSP Husqvarna 340 345 346 350 353...
Poulan 2150 chain saw starts after priming and dies after a few seconds
Take the exhaust off so you can see the side of the piston, if it is scored or damaged it means it has probably been run without oil added to the petrol.
That can cause the problems you are having, if it is throw it away, its not worth repairing
Dec 14, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
How do ireplace gas filter in poulan 2055 chain saw?
the fuel line rots apart you need to replace the line pull the old hose out take a new hose cut down about a half inch cutting the line to about 1/3 slide a stiff wire down the hole and out the gas cap slide the hose over the wire and slide it back til the cut back end pops out put the filter on the end and pull it into place cut to size and install on the carb
Sep 01, 2012 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
Poulan 2150 Woodman Chain Saw When I release the throttle(idling), the chain doesn't stop.Shouldn't it stop for safety reasons? I don't have the maual.
Yes, the chain should stop. There is a metal ring inside the chain housing cover that either broke in half or cracked off the mounting location.
Nov 13, 2010 | Poulan Garden
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
Garden Logo
171 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
