Question about Garden
My flowtron leafeater keeps tripping off after ten seconds,with no load in it, could you please tell me what could be the problem?
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
I just want to ask does the power head turn by hand easily? If so the most probable suspect would be the motor capacitor has failed so the unit does not come up to speed and the thermal overload trips.
Another reason it could be tripping is that there can be corrosion in the motor bearing causing extreme friction / spalling of the motor bearing and the thermal overload is tripping.
Last reason... look underneath the power head to see if by chance there is string or something wapped tightly in between the motor and the power head.
Flowtron seems to be the only source for parts and service and you can contact them here.
FLOWTRON OUTDOOR PRODUCTS
15 Highland Avenue
Malden, MA 02148
Telephone (781) 321-2300
Fax (781) 324-8403
Parts & Service: service@flowtron.com
Sales: sales@flowtron.com
I looked for the motor capacitor on page 11 of the manual here:
http://www.flowtron.com/manuals/Leaf-Eater%20LE-900%20Operating%20Instructions.pdf
and they only list the motor.
Thanks for choosing FixYa,
Kelly
Posted on Apr 09, 2011
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
The motor burned out after one year of use. It was bought in Oct 2009. This year in Oct. it burned up in about 10 min. How can I get a replacement motor? I took it apart, cleaned it, reassembled it...
I would recommend contacting the manufacturer. The warranty was 1 year. If you are at 13 -14 months, I would ask Flowtron for some help in getting it replaced. Sometimes manufacturers are willing to split the cost of a repair that is near the warrany end to help keep a customer satisfied. It is worth trying.
Good luck.
15 Highland Avenue
Malden, MA 02148
Fax (781) 324-8403
Dec 07, 2010 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron LE-900D Leaf Shredder- Spinner flies off.
The screw is a common one, Make sure it is at least a grade 5 or grade 8. The o-ring may be another matter, but should be available at hardware and most definitely a hydraulic hose shop would have it.
Jan 16, 2010 | Flowtron LE-800 Electric Leaf Shredder
Where could I get a replacement motor for a LE 700-1 flowtron
go to www.flowtron.com and call their customer service. That is what I had to do.
Good Day.
Nov 16, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
I have a LeafEater Leaf Blower/Vac 165 mph. I lost the manual and I need to know the ratio of gasoline to 2-cycle oil. Thanks.
Are you sure the brand is LeafEater?
I would suggest using a good brand of synthetic 2 cycle oil at a ratio of 40:1 and you would be fine.
If you happen to have one of the green units by WeedEater, check their website for a manual. You will need to know the model, tho.
http://www.poulanpro.com/node5782.aspx
Oct 30, 2009 | Garden
Flowtron LE 900, The Ultimate Mulcher, just quit
I found a reset switch on the leaf-chipper. I was then careful to fill it more slowly, and to keep out sticks and clumps of wet leaves.
May 28, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Apr 25, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
Mar 23, 2009 | Flowtron LE-800 Electric Leaf Shredder
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
