Question about Senco Tools & Hardware - Others
Senco SFN 2 needs part # LB5005 seal and # KB 5061. Where can I get these parts or repair kits?
    President:
  • Senco Master
  • 1,388 Answers
Best place for Senco parts is www.juldan.com
They have both of these parts in stock with good pricing. Good luck
Posted on Apr 11, 2011
Where to get senco parts australia
Try this company:-
Airco Fasteners Pty Ltd.
1 Short St, Silverwater, NSW 2128
Ph: 02 9737 8377
Fax: 02 9737 9274
Email sales@aircofasteners.com.au
Jul 15, 2014 | Senco Tools & Hardware - Others
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Sns45xp senco dosent shoot anl leak air for the cap
You have worn or broken o-rings in your upper firing and trigger system. You need a Senco repair kit #YK0230 to fix your problem. Fairly easy to do, replace one o-ring at a time to make sure you get them back in place properly and use the grease in the kit liberally. Since you'll have it apart I also recommend you get Senco repair kit #YK0231 which is the lower seals and piston stop. If the upper rings are going bad the lower rings won't be far behind.
Feb 03, 2011 | Senco SNS45XP 16Gauge Construction Stapler
Air nailer vnot operating. blowing air from top close to handle
Your nailer has worn or broken o-rings in the top end. You need a rebuild kit (Senco part number YK0360) to get your gun going again. They are available through most online, after market parts stores. When you get it, remove and replace each seal and o-ring one at a time so you get them all back in their proper place and use all of the grease to lube the o-rings. Use all of the parts in the kit, if one o-ring or seal is damaged the others are not far from failing.
Jan 25, 2011 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
My senco air stapler sns50 is blowing air out the top what is wrong with it
You have worn or broken seals/o-rings inside your gun. You need Senco repair kit #YK0375 to fix it. Use all of the parts in the kit and replace each ring one at a time to make sure they go back in the right place. Lube them well with the grease provided in the kit.
Jan 05, 2011 | Senco Air Tools & Compressors
SENCO Framing nailer suddenly decided not to fire. Air escapes from top of gun when trigger is pulled
You have some worn/broken o-rings inside the gun. You need Senco repair kit #YK0360 to fix it. Fairly easy to replace the o-rings, just be sure to put lots of lube on the rings as you put it back together.
Nov 29, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Sep 03, 2009 | Senco Tools & Hardware - Others
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Greetings, I have a Senco SFN-2 finish nailer.. I put a new senco kit in it... It fires upon connecting air to it but then leaks like crazy at the trigger...???? Why, why, why....???? Looking for a diagram...
you have popped the seal too much air pressure. Ive done it my self lol. diagram dont know sorry but it dont have very many parts should be easy to fix. good luck.
May 08, 2009 | Air Tools & Compressors
Trigger is frozen gun will not fire
I have worked on many senco finish nailers including the sfn2 and have found them to be very reliable except when the wrong type of oil or too much is introduced into the gun. Some oils can swell the orings and cause the problem that you are having. No worries however, orings are available at www.toolpartsdirect.com as well as parts list. An oring kit costs less per oring. You must remove the head to access trigger parts. Part # LB5005 (firing valve) is the part that fails the most on your gun but failure of this part leaks air out of top. You should keep a spare firing valve just in case. Enjoy
Dec 08, 2008 | Air Tools & Compressors
Tools & Hardware - Others Logo
577 people viewed this question
Top Senco Tools & Hardware - Others Experts
John Trevino
yoopertech
Matt Olenzek
Matt Olenzek
Are you a Senco Tool and Hardware - Other Expert? Answer questions, earn points and help others
