Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson animal, have to hold ON switch for it to work
My dyson animal will not stay on. i have to hold the power switch on to vacuum. ive checked for clogs and there arent any.
  • 5 more comments
  • bbfarmer Aug 29, 2008
    On switch won't stay in 'on' position.
  • dth821 Sep 01, 2008
    mine just started doing this also.
  • Anonymous Sep 07, 2008
    same here... first problem we've had with the vacuum... very disappointing.
  • lstehman24 Nov 17, 2008
    I have a Dyson slim and it has the same problem...very annoying and tape does not seem to work at all....
  • chilligan May 11, 2010
    It could be a little more difficult than els1005 indicates. Also likely it is not stuck in the "on" position, but the toggle switch wire (a tiny little metal wire like a mini paperclip) has come "unfixed" from it's position within the switch housing. That little wire is bent in such a way that when you press down on the switch, it goes through a series of gates to clip and hold the switch down. When you press the power button again, it is released from the gates. The problem on mine - which was accessed as els1005 described - was that the bottom of the wire had dropped below a crevice in the bottom of the switch housing (a maroon coloured plastic box containing the switch mechanisms) and wasn't passing through the gates correctly to hold the switch down. Taking a jewelry sized screwdriver, I was able to push the wire back up into its correct position so it could pass through the gates. I'm only worried this is a temporary fix. I'm not a 'lectrician by any means and don't know much about electrical engineering (got a D in that class!), but the toggle switch that connects the metal leads on one side was burnt black. Whether this is normal in electrical equipment, I don't know. If the Dyson burns up, I'll post here ASAP!
    I don't think mine is the Animal, but an original DC07 (had it for 5 years). Probably insignificant, but I've already said I don't know what I'm talking about.
  • Anonymous Mar 29, 2014
    When pushing the button on the vacuum it will not stay on it just pops back off. But when holding down the switch it stays on
  • Anonymous May 28, 2017
    I had the same problem. I took apart cyclone filtration portions and shook out a lot of fine silt, cut the hair out of the brush, and reset the overheat shut off. To do this I pulled the handle down to vacuuming position, laid it on its side, then pressed the power button five times. Viola! Back in working order. This is a magnificent vacuum.
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Posted on Nov 15, 2008
  • tkohanski Jun 13, 2011
    Thank you very much for this information. I called Dyson and they told me it was the on/off switch and to send it in for repair was $125.00. After reading you solution I made the repair myself. Thanks Tom Cleveland. Ohio
  • Jason Renfro
    Jason Renfro Jul 19, 2015
    This also worked for me... your help from November 15 2008 is still pay off 7 years later!!! Love it!
This solution worked for my DC18 also. I didn't even have to take the switch off completely. I was able to reach in and work the power switch up and down until it clicked and works perfectly again.
Posted on Sep 08, 2012
I had the same problem with my animal not staying on. I removed the two star screws from behind after removing the wand; pulled away the housing; manually pushed the on/off button and it just began working again. Must have just vibrated itself out of whack or some such thing.
Posted on Jul 27, 2010
Unplug the power. problem seems to be with the power switch being stuck down. below the power button there's a screw. take that out and you have to really pry the cover off, but there's a switch behind there that is stuck in the on position. flick it around a little and it will go back to normal. good luck!
Posted on Sep 07, 2008
    New Friend:
Thank you so much!! Fixed work perfectly!! I have videos if anyone needs to see it to do the fix.
Posted on Aug 26, 2014
    New Friend:
This worked on my Dyson D25 Animal as well. pulling the switch then wiggling the button with my finger. When I was rattling it around, a very slight (2 degree) twist seemed yielded a very quiet click an the switch began working. It sounds like this is a very common problem. Is engineering listening? Please let us know.
Switches may have problems after about 2000 or more events. Also one aspect that may not be covered in automated (mechanical) testing is that not all events are a full power on. All the time fingers slip or there is a hesitation and there is only a half press.
Posted on Jan 19, 2015
The power button will not stay depressed. Vacuum will work if I hold it down.
It is caused by loose power buttons Spring or broken lock. open the cover & replace power switch.if u not able to do contact mechanic
Mar 02, 2015 | Dyson DC41 Animal Vacuum
How do I fix the power button for my Dyson DC14?
  • You will need to remove the switch cover and replace the main power switch.
Jun 29, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
Aug 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum will not stay on unless I hold down the power button.
Sounds like your switch has gone.
Its simple to replace, only 1 "specialist" tool is needed, but you can substitute for a small screwdriver.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson DC-17 Absolute Animal does not stay running after I push start button. It will only run if I hold the start button down all the time.
switches always fail on the dysons. its a pretty simple fix though. let me know if you need parts and/or instructions on repairing it.
Apr 12, 2010 | Dyson DC28 Animal Bagless Upright Vacuum
We have a dyson 07 and I am guessing the switch needs replacing as it won't stay running unless you hold the switch down. How do you change the switch?
Hi its Darran at Dyson.
We can arrange for an engineer to repair your machine for you. If you would like to arrange this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Jan 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson start button will not stay on. I have to
those switches go bad all the time. replace the switch and it will be fine. let me know if you need the switch
Jan 03, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
6,449 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
