Question about Goldstar GBV241 DVD Player/VCR
Recording on Goldstar dc596m
I am trying to record a program on HBO with a vcr tape. I have tetsed it already and works on channels 2 - 21. But when I try to set the channel for 22 there is nothing at all on the screen what do I have to do if anything??
Please help me with this small issue, Thanks
  • rotinim Aug 10, 2008
    I am trying to record and it is not working
  • bledihysaj Oct 13, 2008
    my dvd is not working the problem is that on the screen of the disk it says progressive scan
  • 275 Answers
SOURCE: VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Posted on Apr 17, 2007
SOURCE: MY DVD / VCR PLAYER MADE BY GOLDSTAR IS STUCK IN A MODE THAT SAYS PROGRESSIVE SCAN MODE ,HOW CA I GET OUT OF THIS MODE I HAVE A GOLDSTAR MDL #GBV441 THANKS
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Posted on May 20, 2007
dodgecharger
  • 254 Answers
SOURCE: vcr to tv connection
There are probably a couple of different ways to hook things up. One is you hook the VCR "in between" the indoor antenna & the set. Hook antenna to VCR RF/Ant In, then VCR RF/Ant out to the Antenna input on TV. Your VCR will then be able to record one channel, while you watch another on TV. To play back the VCR, or do any VCR setup, TV channel must be set to either channel 3 or 4. The other way is to use the Video & audio input/outputs on the VCR & TV. You will need the appropriate cable(s). Match the VCR video/audio outs with the set of inputs on TV. Video and audio out on the TV go back to the video/audio inputs on VCR. In order to view VCR playback, menu setup, you will need to select that input (line, aux, video 1 etc.) on the TV. This hookup probably won't allow the recording of a second channel while watching one. As regards the hft channels, I assume you live in an area where such is being broadcast. The TV can probably be put into a programming mode where it will scan for all available channels, and put them into memory, or they can be programmed manually.
Posted on Jun 15, 2007
SOURCE: issues with my goldstar
Goldstar dvd/vcr combo was stuck in progressive scan. I used the posted solution and now it is out of progressive scan but it continuously reads the dvd and I cannot get the dvd to play. "Reading" conitues to appear on the screen. Any suggestions?
Thanks!
Patsy
Posted on Jan 07, 2008
  • 275 Answers
SOURCE: CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Posted on Jan 11, 2008
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I would like to tape my programs on the vcr(goldstar) I am not used to this product
do you wish to record while watching or while away.....while watching make sure your vcr is set to CH 3...when the show comes on press record
(a blank tape should be inserted) the red button on most vcrs.......while away the channel selector must be on the ch you wish to record...using the remote for the vcr press menu/program a event (this is where your vcr most have the correct date / time and not flashing 12:00)..set the day..time to start recording and time to stop recording..your ch will always be 3..now that vcr is set the main thing is make sure that cable channel selector is on that channel
happy recording
Aug 08, 2010 | Televison & Video
How to record VCR tape on DVD with SV2000
if your vcr only has 2 outs (video / audio you will need a "Y" splitter a 1 female to 2 males )..plug in to dvd in audio left and right and video in........
press play on vcr and record on dvd.........(Please note any Disney tapes will not record on to dvd and some HBO recording may not also)
May 29, 2010 | Televison & Video
Cannot record copy protected message
Hello billwade1216,
I'm sorry to inform you but we are unable to disclose those types of details as it is Illegal, and against Fixya's policy.
Sorry for any misunderstandings, thank you for trying Fixya!
Apr 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Programming Quasar VHQ940 for DTV converter box
I assume you're trying to record from the DTV box. You will have to set the DTV box to play through channel 3 then tell the VCR to record channel 3. So basically the VCR always THINKS it's recording channel 3, but in reality it's recording whatever channel the DTV box is on. You will be unable to used timed recording unless you leave the box on whatever channel it is you're wanting to tape.
Aug 05, 2008 | Quasar VHQ940 VHS VCR
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
Vcr to tv connection
Jun 13, 2007 | Goldstar GVR-E435 VHS VCR
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Televison & Video Logo
130 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
