Question about Campbell Hausfeld Air Tools & Compressors
I have a Campbell Hausfeld CC2300 air compressor. The hose that goes from the compressor to the pressure gauge is leaking. Where can i get a replacement hose?
  • 710 Answers
Hi Paul,
If you go to:
http://www.searspartsdirect.com/partsdirect/part-model/CC2300?pathTaken=modelSearch&prst=0&shdMod=CC2300
and enter your model number you'll find a parts diagram and a parts list. Look at the diagram and determine which part this hose is. You can buy it right there.
Your model number was one the site didn't recognize, so the page I landed you on describes where to find it and how it looks. No doubt you have the correct model number and they just don't carry it. But you might find the part on another model. Then email them and have them check and make sure you get the right hose. That would be my suggestion. I'd like to hear back if you find it.
I hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com.
Handie Andie
Posted on Apr 10, 2011
I have a 2 gallon compressor , no air comes out?
Check if air intake is clogged.
Check if drain valve on tank bottom is open or closed.
Look at pressure gauge and see if pressure is zero.
Adjust pressure so tank will hold 80-120 psi.
Check air lines between compressor and tank to see if they are leaking. Listen for leaking air while motor is running.
Jun 24, 2012 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld manual CC2300 cant find it!
This is the site for CH products. Just enter your model number and you will be able to pick yours. Parts are also available.
http://www.chpower.com/manualsearch/
Oct 30, 2011 | Campbell Hausfeld Cordless Air Compressor...
I have a Campble Hausfeld DK705000AV cordless air compressor that will not charge. Is there any place that I can get parts for it.
If you are having trouble getting a replacement part through Campbell Hausfeld, recommend opening the case, removing the battery and searching for a part # on the battery itself. It may be a generic battery, and possibly can be found without difficulty.
Jun 19, 2011 | Campbell Hausfeld Cordless Air Compressor...
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
I have a campbell hausefield vs series air comp and when it reaches full air supply and shuts off air leaks (alot) out of the switch i replaced and nothing changes.
There is a check valve on the tank where the line from the pump goes to. It should also have a smaller line running to the pressure switch. If the valve or spring inside is broke or stuck it will leak as you describe. You need Campbell Hausfeld part number CV221502AJ.
Dec 22, 2010 | Campbell Hausfeld 5HP 26 Gallon Single...
How do I get an instruction manual?
Try Googling: instruction manual Campbell Hausfeld CC2300 12V RCH Air Compressor
Dec 15, 2010 | Campbell Hausfeld CC2300 12V RCH Air...
Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Jun 28, 2010 | Campbell Hausfeld CC2300 Cordless 230 PSI...
Power supply
I have been told that there official site you can buy another AC adapter, the product number 'SV99400AV' is what your looking for on there site and is also made by Campbell Hausfeld.
But I just looked, and I can't find it on there site, but I hope this information helps somehow at least.
Mar 30, 2009 | Campbell Hausfeld CC2300 Cordless 230 PSI...
Hose from compressor to air tank
Campbell hausfeld parts are available at www.chpower.com, however, you can use standard parts like copper tube or rubber pressure hose available at Lowes lumber or True Value Hardware. Check for cause of failure of the airline, could be from vibration due to loose motor mount or faulty check valve at tank causing back pressure. Enjoy
Dec 09, 2008 | Campbell Hausfeld 13 - Gallon Air...
Air Tools & Compressors Logo
57 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
