Question about Cell Phones
How can I connect GT 19000 to WI-FI What is and where it is WPS touc? Many thanks Felice Volpe
    Genius:
  • 1,098 Answers
Hi there.
To connect the phone to wifi, you may want to go to:
In Idle mode, open the application list and select: Settings? Wireless and network ? Wi-Fi settings ? Wi-Fi.
Find and connect to a WLAN
  • In Idle mode, open the application list and select Settings ? Wireless and network ? Wi-Fi settings. The device will automatically search for available WLANs.
  • Select a network under Wi-Fi networks.
  • Enter a password for the network (if necessary).
  • Select Connect.
Add a WLAN manually
  • In Idle mode, open the application list and select Settings ? Wireless and network ? Wi-Fi settings ? Add Wi-Fi network.
  • Enter the SSID for the network and select the security type.
  • Set the security settings depending on the selected security type.
  • Select Save.
To go to WPS or Wifi Protected Set Up:
  • Select WPS button connection.
  • Press a WPS button on the access point within 2 minutes.
To connect to a WLAN with a WPS PIN,
  • Select a network indicated by the WPS icon and select WPS PIN.
  • On the access point, enter the PIN and press the start button.
Hope this helps. Let me know if you have further questions.
Thank you!
Posted on Apr 10, 2011
What is the WPS pin for canon 3570
Its a wireless protected setup, that is used when the has no idea/experience to set up wi-fi connectivity. Its speed depend up on the other wi-fi connected application. Its meaning is same for applications under wireless connectivity.
Thanks.
Jan 04, 2015 | Office Equipment & Supplies
I have a RCA tablet rct6272w23 and I can't connect to internet what should I do?
Hi
To connect to the Internet with a tablet, you need to have either a SIM card with mobile access (3g or 4g) or a Wifi card in the tablet and access to a Wifi Hotspot. I downloaded the manual for your tablet here:
http://www.rcatablets.com/sites/default/files/CT9272W23%20IB%20English.pdf
and looking through it the first option does not exist for you as there is no facility for a SIM card.
Therefore you need to access a Wifi hotspot - somewhere. It could be your home router, a cafe, a railway station or a multitude of places. In order to access the Internet this way you must follow this procedure:
1. Go to Settings > WIRELESS & NETWORKS > Wi-Fi, and slide the Wi-Fi switch to the ON position.
2. The device will scan Wi-Fi networks automatically and display the available names.
• If the device finds a network that you connected to previously, it will connect to it automatically.
3. Tap a network name to connect to it, and enter a password if necessary.
4. Alternatively, if your Wi-Fi router supports Wi-Fi Protected Setup, tap the WPS icon at the top of the screen, and then press the WPS button on your router.
5. If your network does not broadcast its SSID, tap the Plus icon + at the top of the screen, and enter the Network SSID (name) of the network. If necessary, enter security or other network confi guration details.
In public places you may need to pay to get the necessary access password.
Hope this clears things up for you
Nov 14, 2014 | Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
WPS button
I have a WRT54G router and there is no WPS button.
This is a cut and paste from Cisco engineer:
Wi-Fi Protected Setup or WPS is a somewhat new feature on most routers. However, I believe that the WRT54g was release prior to this feature. The installation disc for your wireless adapter is trying to circumvent network discovery and the process of entering a wireless password by using the WPS feature. Without using the installation disc to setup the adapter should still be able to connect to your Wi-FI network. Only use the disc to install the drivers for your wireless card and the wireless access utility. After you have done this:
1.Open the wireless utility and you should see available networks
2.Select your Wi-Fi network
3.If the network is open (not password proctected) you should be connected immediately
4.If the network is secured (password protected) then you will prompted to enter your password or preshared key
5.After entering the key you should be granted access to the network
Apr 19, 2014 | Linksys Wireless-G WRT54G Router
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Jan 22, 2013 | Netopia Motorola 2247-n8 Wireless Dsl...
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
Unable to Connect to WI-FI with my Samsung Galaxy GT-19000 when scanning it states' UNABLE RO SCAN NETWORK' tried turning on& off and review settings but I'm affraid of making things worse. I have had...
I just had this same problem - I suspect it may have been a new app I installed that changed some settings.
I fixed mine by going into Settings>Mobile Network settings, then tick "Use packet data". Worth a try.
Dec 08, 2010 | Samsung Galaxy S GTI9000 Smartphone
Can i connect belkin to belkin through dsl modem and how
Yes, you can connect:
DSL modem WAN/Internet port on Belkin #1
LAN/network port on Belkin #1 WAN/Internet port on Belkin #2
LAN/network port on Belkin #2 your computer
If the two Belkins are in different rooms, and there are more than one computer in the room with Belkin #2, it makes sense to run ONE (not MANY) Ethernet cables from Belkin #1 to Belkin #2.
Nov 19, 2010 | Belkin Basic Wireless Router
Cell Phones Logo
80 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
