Question about Sanyo SR-6100 Compact Refrigerator
Sanyo refrigerator SR 6100 S stays too cold. - Sanyo SR-6100 Compact Refrigerator
Joe_Rex
  • 114 Answers
SOURCE: SR-172W not cooling
MOST CASES ... THEY ARE NOT LOW ON 134A . TO TELL ... YOU NEED ONLY START THE COMPRESSOR AND HOLD YOUR HAND ON THE SMALLEST COPPER-LINE ... IF IT GETS REAL HOT 110-130 DEGRESS YOU HAVE A CHARGE. IF YOU MOVED THIS FRIG. AT ALL LATELY MAKE SURE YOU LET IT STAND UPRIGHT UNPLUGGED !!! FOR EIGHT HOURS. YOU CAN ALSO SPEED THINGS UP BY: HEATING WITH A BLOWDRIER BOTH THE COLD PLATE INSIDE AND THE BOTTOM OF THE COMPRESSOR ... THIS BOILS ANY REFRIGERANT OUT OF THE OIL AND LETS THE OIL RETURN TO THE COMPRESSORS OIL RESEVOIR THAT IS AT THE BOTTOM OF THE COMPRESSOR. THESE SMALL FRIGS ARE GREAT ... BUT FRAGILE TO MOVE AND DEFROST. OIL CAN GET TRAPED IN THE COLD PLATE AND NEDDS TO BE HEATED OUT OF THERE AND SOME UNFORTUNATELY USE METAL OBJECTS TO DE-ICE. A LOW CHARGE WILL NOT FROST THE COLD PLATE (EVAPORATOR)EVENLY AS IT SHOULD. LOW CHARGES (AFTER YOU HAVE DONE THE ABOVE) ... WILL ICE UP IN JUST A SMALL SECTION WERE THE PIPES AND CAP-TUBE GO INTO THE COLD PLATE. THESE DONT LEAK UNLESS SOMEONE TOOK A ICE-PICK OR EQUALLY AS DEVESTATING TOOL TO DEFROPST IT. ONLY WAY TO DEFROST QUICK IS WITH HAIR DRIER ...DO NOT PROP-IT UP IN THERE AND WALK AWAY .. YOU CAN MELT OR WARP INSIDE PLASTIC HOUSING !!!!! THEY ALL NEED MANUAL DEFROSTING THE MINUTE ICE STARTS ACCUMILATING. OR BUY A APPLIANCE GRADE HIGH AMP (10 AMP) PLUG IN TIMMER AND SET TO GO OFF AT 3AM AND COME ON AT 4PM ... ONLY 1 HR. IF THERE IS A VISABLE HOLE IN THE EVAPORATOR COLD PLATE ... IT IS ALUMINUM AND FORGET ABOUT EXOPY KITS TO REPAIR THEY ONLY LAST A YEAR IF THAT. IF YOU CALL TO HAVE IT REPAIRED RIGHT WITH SOLDER ... USUALLY A REPAIR LIKE THAT WILL NOT BE WARRANTIED AND PROBUBLY COST MORE THAN TO BUY A NEW ONE. GOOD LUCK.
Posted on May 07, 2007
docjohn174
  • 943 Answers
SOURCE: Sanyo Eclipse refrigerator (Model# SR-4433S)Has
HI thanks for the question. if theres a puncture in the coils . scrap it way too expensive. sorry.
Posted on Oct 16, 2008
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
Posted on Mar 25, 2009
SOURCE: Sanyo counterhigh refrigerator model SR-4911.
remove shelves and insert keg.
Posted on Feb 03, 2010
  • 534 Answers
SOURCE: what kind of bulb I should use for sanyo
purchase an appliance bulb they are available at any hardware store. Ask an eployee in the appliance department and they will be glad to help
Dave
Posted on Mar 18, 2010
What is the coolest temp. for Sanyo SR-LV209f... 5 or 1
On any refrigerator that I have owned, the higher the number the cooler the temperature. Thus 5 would be the coldest temperature setting. If you set it too cold, items will freeze in your refrigerator.
Aug 14, 2015 | Sanyo Refrigerators
Sanyo sr-4433s not cold broken while removing ice
There is a sensor wire in the vicinity of the ice-box... If you've forcible removed the ice build up... you may well have damaged this and hence the thermostatic wire will need replacing.
May 15, 2014 | Sanyo Refrigerators
Sanyo SR-4800W freezer is ok and cold stoeage is warm. Need to fix the problem.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Sanyo SR-4800 Top Freezer Refrigerator
Sanyo SR 3620W countertop height refrigerator repair question
yes it can be repaired but it might cost you more than a new one. check with local refrigeration company on quote before they come.
May 09, 2008 | Sanyo SR-3620 Compact Refrigerator
Apr 03, 2008 | Sanyo SR-366 Compact Refrigerator
Broken glass shelves- SR-4433S
you would have to order them from sanyo at www.us.sany.com
Oct 20, 2007 | Sanyo 4.4 cu. ft Counter-High...
Fridge and freezer wont get cold
check the thermostat for power out to the compressor
Aug 20, 2007 | Sanyo SR-4310 Compact Refrigerator
Sanyo SR-6100 Compact Refrigerator Logo
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
