Question about Sony Handycam CCD-TRV208E Camcorder
Code:31:23 and 31:22 sony camera - Sony Handycam CCD-TRV208E Camcorder
Sony a100 error 56
The Error code indicates the Self diagnostic message of the Camera. This message can be clearly identified by the help of a Sony Authorized service technician. The
Error code 56 indicates an issue which can be resolved by the help of a service technician. This error code may be an issue with the Shutter mechanism. Try resetting the Camera by selecting the Reset Default option in the Setup Menu 3 option. Also, try removing and reinserting the battery after 1 minute. If not resolved, get the unit serviced.
Thanks.
Oct 21, 2010 | Sony Alpha DSLR-A100 Digital Camera
Password problem to change setting for my Sony Cyber Shot camera
With the camera off hold the Zoom to the 'W' side. While holding the zoom press the play button, when the camera powers on it will ask if you want to reset. Press ok.
The camera will then ask you for a 4 digit reset code. The code is:
7669
Have fun!
Dec 30, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
Sony DCR-TRV19 Problem: None of the functions except cassette ejection will work. Error Code:C:31:23
Error code 31:23 shows problem in Take-up Reel section of your Sony Camera. If you know about camera repair, please check Take-up Reel section in tape mechanism and if you don't know, please contact nearest Sony Service Center for proper repair.
Aug 17, 2008 | Cameras
Camera Case will not close
I solved my Sony Camera problem by throwing the camera in the trash and vowing never to purchase a Sony Camera again. When I saw many other people posting the same problem on the internet, I came to the conclusion this is a major problem with Sony Cameras.
Jun 18, 2008 | Sony Handycam DCR-IP5 Micro MV Digital...
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
E code
http://www.fewin.com/sony/sony.htm
I found this while hunting for another error which I found as well.. Hope this helps! They say what ytou might be getting is a focus error! Good Luck...
Feb 19, 2008 | Sony Mavica MVC-FD200 Digital Camera
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
ERROR CODE 0x5b
This error message is an indication that a problem may have occurred with the aperture assembly in the camera. To resolve this issue, service will be required.
Feb 03, 2008 | Sony Alpha DSLR-A100 Digital Camera
Error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Nov 19, 2007 | Sony Handycam DCR-TRV80 Mini DV Digital...
Flashing text on screen
I am sorry that I can not tell you exactly what that code means, Sony only releases the complete list of error codes to their employees. What I can tell you is that many error codes can be clear by reinitializing the camera’s internal software. In the Menu select Initialize.
If resetting the program does not clear the error then it’s a hardware problem. In the USA this camera has a 1 year warranty. Contact Sony repair at http://www.sony.com/service or 1-800-222-SONY (7669).
Nov 02, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Handycam CCD-TRV208E Camcorder Logo
37 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
