Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I have purchased a hotpoint aquarius 1000 washing machine and when i set it on to a wash cycle and turn the power on nothing happens, how do you start the washing cycle?
    Brigadier General:
  • 6,277 Answers
I think the best thing for you to do is to obtain a manual which should not only give you the answer to this but also any future queries which are bound to occur.
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.Good luck,
John C.
Posted on Apr 09, 2011
Hi, I have a Hotpoint Aquarius WF530 washing machine. When I put on a wash program I hear the pump running as per normal part of cycle but nothing else happens. Drum does not fill with water... If I turn...
most probally the control module (bottom of machine) emw electronics are your best bet for a replacement, as otherwise they have to be programmed by hotpoint
Sep 09, 2013 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
When turn washing machine on about 5 - 10 minutes into cycle sets trip switch off and no power. Happens everytime try to use it - tried different sockets - checked fuse. We have hotpoint aquarius extra...
heater probably down to earth and only solution is to check. to test, remove wires from heater, tape them up for safety then start cycle and see if fault still happens
Jun 29, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
186 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
