I cant remember how to hook up the speakers to the system
  • 3,287 Answers
Speakers use a cable that consist of 2 insulated wires. The two wires are identified by one or more ways: 1) one wire may be golden colored and the other white or silver colored, 2) the insulation on one of the wires may have a raised ridge, or 3) the insulation on one wire may have some marking along the surface where the other will not
The terminals on speakers and terminals for the speakers on the amplifier will both have a (-) and (+) symbol for each cable (one for each wire). I like to assign the (+) terminal to the golden colored wire or the insulation with the rib or marking on it, and the (-) terminal to the white or silver colored wire or on the smooth or unmarked insulation. It does not matter which wire you assign to which terminal - as long as the (+) and (-) terminals of the speaker connects to the (+) and (-) terminals on the speakers of the amplifier (you should see to it that they do not get crossed so that the (+) of the speaker is connected to (-) terminal for the speakers on the amplifier).
Connect each speaker location to the corresponding speaker terminal on the amplifier (the front right speaker to connect to the front right speaker terminals on the amplifier - continue until all speakers are connected). Failure to connect correctly will make fading front to back and balance left and right work unexpectedly.
I hope this helps and good luck! Please rate my reply. Thank you.
Posted on Apr 09, 2011
Cant get sound through tv
What model/manufacturer? Most systems that have their own speaker outputs do not output audio from the hdmi connection to the tv. They assume your are going to use the system speakers.
Jun 04, 2013 | Audio Players & Recorders
I HAVE A INTEMPO BLUTOOTH SPEAKER BUT CANT PAIR IT BECAUSE I CANT REMEMBER THE CODE FOR IT
they usually give them basic codes unless you have managed to change it. they ae usually four digits. Most common ones are :
1234
5555
0000
1111
try those
Jan 07, 2011 | Onkyo SKS-HT500 System
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
PlasmaSync 42MP3 42 in. Television: i bought a anec hooked up speakers i cant get audi...
I dont' have the fix but I do have a work around. You can hook your source directly up to a surround sound unit if you have one using red and white audio cables to the aux input on the surround sound system.
May 07, 2010 | NEC PlasmaSync 42MP3 42 in. Television
I cant remember how the wires hook up from my sound card to my Klipch system with a sub. Thank you
you would probably need an amplifier or if it does have a head phone-like connector that can fit on soundcards green slot or speakers slot
Feb 03, 2010 | Creative Labs Sound Blaster Live! 5.1...
I just hooked up new speakers and I now cant hear them.
Please keep the old speakr and restart the system. Also check the Sound settings through control panel -> Sound
Feb 01, 2009 | Ozaki DT-500 3-Piece Speaker System...
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
Hooking up speakers
I'm sure you hooked it up the correct way,This rt2250 is a problem to almost everyone.I have two of them and they both present all types of faults
Jul 27, 2008 | RCA RT2250 System
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
Boston 746 speakers
they might have had a mini amp installed in each speaker some models of speakers have that feature to where u have to hook up power and also the regular speaker connections to the radio system basically even if you have a radio with some power then the speakers may have some type of crossover or something that makes it so if u dont have the power hooked up to them then they wont work right... but there are some speakers out there that dont do that, or it could be that if the stereo that u r using may just be that it has barely any output so it doesnt power the speakers... option 1, if it is the stereo then u will eather have to go to a car shop that sells the self powering speakers "not as cheap as regular speakers" and get those or, option 2, which consists of having to install a new stereo system with more power "remember the system hass to have a little more power than all the speakers combined together..."
Apr 02, 2008 | Boston Acoustics 746 Coaxial Car Speaker
61 people viewed this question
 Grubhead
Grubhead
