Question about Vantec CB-IS100 IDE to SATA converter IDE / EIDE, Serial ATA, ATA-133 Drive Case
Hello....first question, is the Vantec IDE to SATA compatible with windows 7 64-bit? Thank you Ted
  • Anonymous Mar 31, 2014
    not reading in windows 7
    Novelist:
  • 120 Answers
Win 7 should recognize the drives. However, whether your current hardware will recognize the drives is another question.
I've seen posts where it works in some situations, and not others. Amazon has 10 reviews with ratings running the gamut. Seems to be a "Hit or miss" proposition.
Amazon link:
http://www.amazon.com/Vantec-CB-IS100-SATA-Converter-Black/dp/B000Z3K47G/ref=cm_cr_pr_product_top
Posted on Apr 12, 2011
Hello, I try to install Windows XP Pro SP3 on a Compaq Mini 102 but Windows installation don't found the Hard drive. Display : Windows XP Professional Setup ============================ Setup has...
try setting the bios for the hd to ide compatible
windows xp does not include sata drivers which is why you can't detect the hdd.
if you set it to ide compatible it should work
Apr 10, 2011 | Compaq Mini 102 NetBook
How Do I exactly make a 500gb sata hdd work with this p4m266a ndmx motherboard? It doesn't appear to have a sata port and using the sata compatible cable did not help. Thanks
if your motherboard does not have SATA, purchase a SATA - PCI card, they cost something to the direction of 10 to 20 $ and give you 2 to 4 or more SATA ports.
Feb 12, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
Dec 26, 2010 | Vantec CB-IS100 IDE to SATA converter IDE...
How to set as master
u need change in the mother board settings by seeing IDE 0 / SATA 0 , 1 or change in device in jumper settings by seeing in the device cover.
Apr 17, 2010 | LG GSA-H10A Burner
Hi I got a Dell Inspiron 6400 laptop. The current HHD is the seagate momentus 5400.3 120g. This is now damaged. Can I use the Seagate Momentus 5400.6, 320 G, 5400 RPM SATA2. Will my laptop support the 320g...
Hello: I see no problem using a bigger harddrive in the unit,the only concern I think you might have is to purchase a hard drive caddy for the interface, Especially if the current hard drive is an IDE Interface, You can purchase a IDE to Sata Interface caddy, to support the drive Interface if it's an IDE format. You might want to check with Dell for compatibility first before purchasing the Sata Drive.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
I want to install Windows XP on my IDE 2nd HD
- sata has no master
- i presume u want the OS on the ide drive, and not just that the ide drive to have "C" assigned to it! So : 1 - U can copy the data form the ide to the sata, and then reinstall the OS on the ide (note: the OS will start up a bit slower do to the slower ide drive !!!) and so it will become the C drive ! And u can assign to the sata what ever letter u wish...
2- if u don't want to reinstall the os u can do a copy of the os and put it on the ide drive(not just copy the files !! it will not work!!!). U cold use clonezilla for example... But probably the first method wold be safer ....
Jan 07, 2009 | Microsoft Windows XP Professional
Conflict between Promise Ultra133 and SATA RAID controller
Check that your RAID controller and onboard SATA controller aren't in a compatibility mode. You can put them in this mode while you have no SATA driver installed in Windows.
This tricks Windows into seeing the SATA drives as regular IDE drives. Your BIOS then has a spasm when it see's another IDE controller there, and just uses the card instead.
Make sure the SATA drivers are installed first, otherwise anything SATA will stop showing up. (and your Windows just won't boot if it's on a SATA disk and you take compatibility mode off) =-]
Aug 09, 2008 | Promise Ultra133 TX2 ATA Controller
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
Vantec CB-IS100 IDE to SATA converter IDE / EIDE, Serial ATA, ATA-133 Drive Case Logo
242 people viewed this question
Top Vantec Computers & Internet Experts
Willem.
Willem.
Piyal Perera
Piyal Perera
David Payne
David Payne
Are you a Vantec Computer and Internet Expert? Answer questions, earn points and help others
