Question about Sony UVW-1800P VCR
URGENT, PLEASE ! I have a SONY UVW 1800 with a tape inside that I can't remove. On the display is written the following message: "Error 02-674". How can I solve this problem? Thank You
    Problem Solver:
  • 11 Answers
02-674 - Failed to detect the T reel FG during PLAY and REC. No signal from the Hall sensor
Posted on May 03, 2011
No readout on front panel. UVW-1800
No front panel readout on a UVW-1800 is caused by the audio bargraph display failing. This display has an auxiliary power supply in it that provides power to the front panel display.
Oct 15, 2009 | Sony Televison & Video
Sony UVW-1800 error message: 02-274 -- What does this mean?
I found a site where the error code are.
http://z.baidu.com/question/97641503.html
02-274 Failed to detect the T reel FG during threadingI hope this helps
Sep 26, 2009 | Fuji M321SP Betacam Tape
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Tape stuck in sony uvw-1800
02-874 error code signifies a defective takeup reel. The reel is not winding the tape in, so the deck won't go through the eject procedure. Check the connection to the takeup reel motor; if that's OK, the motor itself may be bad. Rarely, the takeup reel motor assembly will need to be replaced; usually it's a connection problem.
Jul 02, 2009 | Sony UVW1800 VCR
UVW-1800 SONY VTR - s-reel error
Both these error codes indicate a problem with the supply reel motor.
The first code (02-058) indicates that the reel motor is drawing too much current, which could be caused by a bad motor, defective driver circuit, or even a bad tape. The second code (02-803) indicates tape slack, caused by the defective supply reel motor. FIRST thing to check would be a possible bad tape. Try different tapes and see if the problem persists. If it does, it may be time to find a technician.
Mar 16, 2009 | Sony UVW1800 VCR
Sony UVW-1800 Error Code
I just found this post on another site :
tsvservice- 29th Jun 2007 14:0109-221 is "failure to complete threading within the specified time". in plain talk, the mechanism in the deck that threads the tape around the heads is not working. this could be a bad motor, bad gear, or even a bad tape.
Feb 15, 2009 | Fuji M321SP Betacam Tape
Mensaje error 02-395 on a Sony BETACAM UVW 1800
error code 02-395 points to a problem with one or both reel motors. a good technician should be able to fix this easily.
Jan 21, 2009 | Fuji M321SP Betacam Tape
Digital betacam tape stuck in Sony UVW-1800 deck
Digital tapes should still eject normally (they are the same size and shape) which indicates that it has jammed somewhere inside.
If you want to fix it yourself you will have to remove the cover and check the tape.
If the cassette hasn't spooled up and all the tape is inside the cassette you should be able to unscrew the carriage (the cradle that takes the tape in and down) and remove it that way.
If the tape has spooled around the heads there is a cog (can't remember the exact position of it) arranged vertically near the side of the machine that you can manually wind the spooling arms back into the cassette.
Good luck
Dec 29, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
SONY uvw 1800 Error Code 02-454
The unit powers on, the drum shows only 0005 hours on it, but the display says it has an "Error 02-454" Error Code, and says "REC Inhibit", and it will not accept a tape. When this unit is powered on it shows error code 02-454 which is:
S-REEL FG COULD NOT BE DETECTED WHILE IN FF/REW MODE.
You can cross-reference this error code at the following web site:
http://www.johnjvsvisual.pwp.blueyonder.co.uk/UVW1600-1800%20error%20codes.pdf
From what I’ve been told this is a very easy fix for someone that knows how to work on these. It is a very clean machine, inside and out, and I am sure it is well worth getting serviced and put back in use
Aug 02, 2008 | Acer TravelMate 3260-4542 Notebook
Sony UVW-1800P VCR Logo
342 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
