Question about LG ZW6500R Air Conditioner
I have a zenith AC model ZW6500R, It was installed one year ago, It simply dosen't blow cool air anymore. Any info would be very much appreciated. Thanks Mark
  • 413 Answers
Generally after one hard summer these units need servicing especially if it is running in a dusty area. Check the filter in the front and if possible, pull the unit out of the case and check the inside of the rear coil (located behind the motor fan blade) The coil is probably stopped up and the unit is overheating and not able to cool properly. You may be able to shine a flashlight through the side of the unit and see if the coil is dirty.
Posted on Apr 10, 2011
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Where do i put the freon in the zenith ZW6500R
Your uncertainty suggests this task is best left to a professional.
Aug 14, 2014 | Zenith ZW6500R 6,000 BTU WINDOW AIR...
Where do i put the freon on the zenith zw6500r
Does it even have a port to put gauges on
or add refrigerant?
Most small units are charged & the lines cripped
& soldered. You have to add line taps
You can't work on that yourself
I had to go to school at a university for 5 weeks, for
that knowledge,or you don't work on it, where is was
working
What Type Refrigerant?
There NEVER was Freon
That was a trade name for Dupont,no longer used
In fact their dupont paint division has been sold to
an investment firm,that is why it no longer is on
Jeff Gordons NASCAR cup car
Aug 14, 2014 | Heating & Cooling
Goodman heating system
It really depends on the type of system you have. You will either have a furnace, high efficiency furnace, heat pump system, heat pump with gas or electric back up heat. All these systems operate differently and the problem that you are having could be caused by multiple issues, depending on which system it is. More info will be greatly appreciated. Make sure to check all filters and air flow first before going any further. The system could be over heating and tripping a limit, causing the system to stop producing heat until the unit has cooled back down.
Dec 06, 2013 | Heating & Cooling
The heater is blowing cool air . Is not heating the car
check coolant level first. would need to know year make and model for anymore info
Dec 31, 2012 | Cars & Trucks
Where can i buy freon for ZW6500R Zenith window unit. 66012
Freon is no longer used for window AC units. You need R142a refrigerant gas. Most auto supply stores and even Walmart carries it. However, having the gas is one thing. Having all the proper equipment to evacuate and recharge your compressor is another. Please be careful. It's best left to the pros.
Jun 30, 2011 | Heating & Cooling
My air conditioner stops cooling. Occasionally, it will just function on fan mode even though I confirm that it is on cool mode. Warm air comes out even on the absolute coldest setting. I have to turn it...
If after reset the A/C cools then the fault seems related to the thermostat or the cut off pressure switch or load cut off.
However is there is no cooling at all the compressor and the gas pressure- check for leak if gas is absent.- must be checked .
If compressor is suspect you must check the estimate and decide whether it seems better to scrap and buy a new one.
May 18, 2011 | LG ZW6500R Air Conditioner
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
It will cool for a bit then switch to fan which blows hot air (from outside most likely) then goes back to cool air for a bit....never happened in past 3 years i've had the unit & there is no water...
If it has an energy efficient installed and turned on; it will do just that. If it does not, then, it is possible that the unit needs to be turned off until the tubing defreezes and it may be a possible solution...if not, then ...call a repairman. God Bless, ac
Jun 26, 2009 | Ocean Aire ArcticAire 6012 Air Conditioner
LG ZW6500R Air Conditioner Logo
391 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
