Question about Krups Aroma Control 229 Coffee Maker
The water level gage is dirty and hard to see a couple of cup #s.Does this come apart for cleaning.Don't have a manual and scared I might break it.
How to set the float level in an etq tg1200 generator
Float levels don't just go bad. But that said you pull the carb and turn it upside down and set the float to be level with the bottom of the carb (bottom with the carb upside down.) Most new stuff doesn't have an adjustment. They break fairly easily. Don't ask how I know.
As long as you have it apart, pull the float and hold it down in a cup of fairly hot water and see if it bubbles which would indicate a hole in the float which would let too much gas into the carb causing flooding.
Make sure you clean the needle valve and seat and the carb inside while you are at it.
Jan 10, 2018 | Electrical Supplies
Good Day I I would like to clean the shower cap as the water is hardly coming through. I managed to get the screw out out but the cup is not moving. Please Help. Elsa Kruger
Sometimes, you can put CLR in a cup or the like and simply hold it up to the head for a bit, soaking the head to loosen the lime scale buildup. Sometimes it works. You may need a couple of pipe wrenches to get the cap off, one to hold the pipe in place so you don't break it, and one to turn the cap. If you're getting that kind of hard water build up, the buildup has "glued" the cap on, it will be tough to get off however you do it.
Oct 30, 2017 | Home
Coffee grounds in the coffee
There are a couple things that could cause that, that I experienced:
1. I found that the water injection needle sometimes gets dirty. Coffee grounds are in it and cause the water to go over the top and wash coffee past the k-cup into your coffee cup.
You can use a paperclip to clean out the needle.
2. There is a whole in the k-cup somewhere or the lid is not properly / or strongly enough glued to the k-cup. The water-pressure then pushes coffee out of those holes around the k-cup into the coffee mug.
3. The plastic insert where you put the k-cup in is dirty itself (I have to clean it every now and then).
4. The coffee in the k-cup is ground so fine that it gets pushed through the whole on the bottom that is being punshed for the water to escape.
Feb 27, 2015 | Keurig B60 Coffee Maker
Oil pressure on my 1996 Dodge Ram pickup is running low even though my oil level is fine
have the oil pressure checked with an independent gage as sometimes gages in the dash don`t show correct pressure. how long has it been since the oil was changed as oil when it gets dirty it thins out and can affect oil pressure. if you don`t hear any ticking with the motor running chances are the pressure is either good or just a little low. testing oil pressure with an independent gage will tell the tale.
Aug 21, 2014 | Cars & Trucks
How can i clean the fabric softner dispenser? I can't get it apart to get all the black gunk out of it.
they don't separate,the best way to clean it out is to lift it off the clothes mover and soat it numerous times in very HOT water to melt the gooey residue in the cup then rinse out and replace cup
Sep 15, 2011 | Whirlpool LSR9434PQ Top Load Washer
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
Hi, i have a dirty window , have cleaned both sides without touching it. think its between the glass and the liner. can' find my manual. can i take the bake of the door glass off some way to clean...
Hello, Thank You for using FixYa. I will be helping you today. It is hard to take apart without breaking it! It is held together with all plastic clips and they break! But you can by putting a putty knife in the inside door seam all the way around and pry the clips down to pop the door apart.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Jenn-Air JMV8196 Microwave Oven
The filter assembly in my LG dishwasher is always getting dirty.
Hi Jim,
Make sure that all the spray arms are clean and not blocked firstly
Pour a half a cup of white vinegar straight into the bottom (sump) of the dishwasher and run it on fast wash.
The vinegar has a small acidic base which breaks down fats etc.
This may fix the problem, or there could be another problem. It would be hard to tell without looking at the unit itself.
Jun 17, 2009 | LG LDF8812 Stainless Steel Built-in...
Took it apart to clean it now i have unscrewed and a spring has come out that makes the door to the filter open and close. oopps
A clean coffee maker is essential to good coffee. Residue of stale coffee oils will interfere the brewing that caused only little produced. It is suggest regular cleaning of your coffee maker according to manufacturer recommendation.
I took everything out, got a small piece of fine sandpaper, held the plunger in with a pencil, turned on the grinder and sanded the round top portion of the grind basket driver. It takes a few times to get a good snug fit that’s still easy to remove.
The instruction manual that came with the pot will tell you to use one cup (measuring cup) of "white vinegar" and fill the rest of the reservoir with regular water. Turn it on and let it perk the mixture through the system. Then perk a couple of pots of plain water to flush out the rest of the vinegar.
The books say to do this once a month to keep things clean and the coffee tasting great.
A professional machine that is plumbed into a water supply must be thoroughly disassembled, and each part soaked in acid, and manually cleaned. Unless your water is exceptionally hard (you should have a water softener inline with the machine in hard water areas) this should only need to be done every 5 years or so. Heads and screens and filters should be soaked every day in a cleaning solution available from any professional machine supplier. A machine that is not plumbed should have a small amount of Puly brand cleaner added to its tank, and run through several cycles every 3 months. Puly is available thru machine suppliers, but there are also several other brands that do the same. Visit your local coffee machine shop for a good cleaner.
Hope this may help;
Regards,
VOTIT
Sep 23, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Dishwasher not cleaning
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Sep 13, 2007 | Dishwashers
Krups Aroma Control 229 Coffee Maker Logo
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
