Question about Hamilton Beach Proctor Silex 17150 Iron with Auto Shutoff
My procter silex iron leaks while i am ironing. can it be stopped?
SOURCE: iron leaks water while ironing
Seal on iron is disolved. replace iron
Posted on Aug 31, 2009
Testimonial: "your information was very helpful."
maintenacemi
  • 95 Answers
SOURCE: water leaks
poly seal{white} perished where comes from tank to element plate
Posted on Nov 18, 2009
carlsbiz
  • 1124 Answers
SOURCE: My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
Posted on Sep 23, 2009
heatman101
  • 43501 Answers
SOURCE: Hamilton Beach Ultra Steam Iron Model #15410
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
heatman101
  • 43501 Answers
SOURCE: Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
I just bought this iron in March 2015. The iron leaks water all of my clothes when I press the steam button. I have it set on the highest setting for iron and steam.
Increasing the temperature setting can ease this issue, however it is important to consider the type of fabric you are ironing.
1st option: Fill the iron up, and let the iron stand as the iron heats for little while before using. This may allow more of the water to be converted to steam.
2nd option: You could try using deionised/distilled water in your iron.
If you find that the water leaks out sporadically, it may be worth pushing the steam button once or twice before applying it to clothing.
I have attached a link with a little bit more information How to Stop Steam Iron From Dripping
Apr 30, 2015 | Irons
How to stop leaking
The best solution for this is to pour out the water when you're done with it. The manual suggests that you set the iron to "dry" setting and then open and close the steam control to push out remaining water, all to prevent scaling. (Do this with the iron unplugged)
Jul 03, 2014 | Rowenta DZ1700 Iron
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
Iron was leaking and now stopped working - 2 months old
Try using different water...
heatman101
Apr 01, 2010 | Sunbeam 4214 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
I have a rowenta iron. When I am ironing the
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
New iron, stopped heating and leaked water
heatman101
May 22, 2008 | Black & Decker D2030 Iron
Shark iron
I bought this Shark iron last July and I even saved the receipt!!But I threw the box away. The water is leaking out of the bottom. I bought the expensive Rowenta before that, and that one leaked all over my ironing. And I cleaned these irons faithfully every month. I need a toll free number for Shark
Nov 13, 2007 | Euro-Pro Shark GI490 Iron
Hamilton Beach Proctor Silex 17150 Iron with Auto Shutoff Logo
198 people viewed this question
Top Hamilton Beach Irons Experts
Jim Thurston
Andrew Taylor
Andrew Taylor
richie46
Are you a Hamilton Beach Iron Expert? Answer questions, earn points and help others
