Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Can you email the mower(cutting belt) diagram for the Husqvarna LGT 2654
  • 252 Answers
Hi there pauly46 here
check out this web site
http://www.partstree.com/parts/?lc=husqvarna&mn=LGT+2654+%2896043003600%29+%282007-05%29
or take a look at this site
here is web site for lgt 2654 owners manual , it has belt routing , and deck installing / removing instruction in it - quite helpful
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602053.pdf
cheers pauly46 hope it helps
Posted on Apr 10, 2011
Will the transaxle from a Husqvarna GTH 2448T Hydro Gearr part # 316-0610 bolt into a Husqvarna LGT 2654 that currently has a broken axle in a Tuff Torq transaxle
Yes, the axle will fit the frame, but the pulleys and idlers will need to be set up. There is no cross reference chart so you would have to create the belt routing by trial and error. Belt length would also have to be determined.
Aug 07, 2016 | Husqvarna Garden
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
How to install drive belt on Husqvarna 2654 LGT riding lawn mower
U should never have to remove the steering column. Most of the time, you have to drop down the pulley on the crankshaft
Nov 05, 2015 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Diagram for 25 horse 54 inch drive belt for husquvarna
PDF]OM, LGT 2554, 96043006100, 2008-12, Ride Mower
www.husqvarna.com/.../HUSO2008_USen_O0802072...
Husqvarna GroupLGT2554. Owner's Manual / 96043006100 / 2008-12. 03002 ..... mower blade drive belts in the Service and Adjustments sec tion of this manual. Verify that the .
Aug 25, 2015 | Garden
Why would a husqvarna lgt 2654 not do anything when you turn the switch on? the switch has been replaced the fuse is good and a new sylenoid
Check the battery and its connections. If you've replaced the solenoid, check the connections on that too, make sure they are all clean and tight and that you haven't inadvertently left one disconnected.
Jul 01, 2014 | Husqvarna Garden
Operator presence switch cuts off engine even if blades not engaged
Hi, you must have the blades disengaged and the park brake locked on before you can get off it. Regards Phil.
Jun 26, 2012 | Husqvarna Garden
LGT 2654 Husqvarna bottoms out on cut selection 5, how do I fix?? Have tried both rear linkages with 3/4 wrench all the way out, did not improve.
Gage wheels not set properly?
On most mowers, the gage wheels should be just a bit off the ground when sitting on a level surface. Most owners manual give a suggested setting for these wheels.
Oct 12, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Belt diagram
You can find the diagram here:
http://lawnandgarden.manualsonline.com/ex/thread/view/idThread/340092
Aug 03, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna LGT 2654 Manual Needed
Use this link www.usa.husqvarna.com go to support and a drop down will appear go down to product manuals on the next screen that comes up you'll see manuals checked off the box next to that type in LGT 2654 and it will give you 4 different manuals to choose from.
Jan 03, 2009 | Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
283 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
