Question about Tecumseh 5hp Engine Snow King Mtd Blowers Lh195sp67517
My 13 HP will not stay running after a few minutes. I have changed the plug, ignotion coil, air cleaner. I took the carb apart and cleaned it. Blew out all the passages. Still will not run very long.
3 Suggested Answers
  • 85 Answers
SOURCE: my 5.5 hp tecumseh engine
check the fuel lines for cracks or holes and the primer bulb very common problems
Posted on Feb 06, 2011
  • 85 Answers
SOURCE: I have a Tecumseh 5
try changing the plug may not be getting enough spark to start
Posted on Feb 07, 2011
My 5 hp craftsman tiller won't stay running changed gas sprayed carb new plug started it ran ok next day starts won't stay running dies fast like no fuel but can smell gas.
when it dies see if it will restart using a shot of starting spray in the air cleaner if it starts or sputters, sounds as if you have a plugged up carb you will need to dissasemble and soak in white vinegar for a few hours to un clogg (carefull with any gaskets)
if still nothing even with spray then you have a weak/defective coil or dammaged spark plug (start with plug replacement)
Aug 06, 2014 | Garden
2003 volvo s40
worn fuel pump / low fuel pressure / engine management fault ?
Dec 23, 2013 | Cars & Trucks
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
I own a 1997 fatboy 1340 evo with 26,000 miles on it,, i have straight pipes no baffles and a nice custom air cleaner and a screaming eagle power comander under the seat,bikes been running fine for a year...
that maybe part of it but the carb needs ajustin and cleanin--backfire is from a rich condition-so the float level can be wrong or the jets have issue--also make sure ur gitten proper spark voltage cause if low then not all gas is burned
Jul 21, 2011 | Harley Davidson FLSTF Fat boy Motorcycles
Huskee Rear tine tiller
-How about spark plug...? Did you change as well...?
-Make sure turn on the gas line.
-Try again.
Good luck. It's closed for garden time.
Mai
Jan 08, 2018 | Mtd Troy-Bilt Bronco OHV Tiller
Car back fires in the engine and wont stay running after a few tries it will but stalls then turn key and runs ok untill its cold again?anyone have a clue??? plugs have been changed and check engine light...
Most probably the vac is leaked. Spray some carb cleaner at the intake (while the engine is running) and see if the sound changes after addinh the carb cleaner. If it still misfires add some more carb cleaner to clean the nozzles of the MPFI system. it should help.......sodeep
Jun 23, 2009 | 2003 Kia Spectra
Pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
May 16, 2008 | Karcher 2500 PSI Pressure Washer
Tecumseh 5hp  Engine Snow King Mtd Blowers Lh195sp67517 Logo
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
